28
I've seen warnings that it's bad to mix new and old batteries -- why?
Is it a matter of a battery's age or a battery's voltage/current (remaining)?
Coldblackice
  • 1,699
A simple model of a battery is a chemical reaction which produces a constant voltage. But, this chemical reaction takes time. A simple model of the limited speed of that reaction in electrical terms is a series resistance:
When the battery is fresh, R1 is small. As the chemical energy is depleted, R1 gets bigger. Why this happens is complicated, and I'm not a chemist, so I can't tell you in detail, but it has to do with the reactants being used up, and the battery plates getting covered in cruft, and so on.
This resistance, even though it's a combination of electrical and chemical effects, isn't exempt from the laws of physics. It still experiences a loss according to Joule's law:
$$ P = I^2 R $$
This loss of electrical energy must be accompanied by a gain of thermal energy.
If you aren't mixing batteries, then as the batteries become dead, all their resistances rise about the same, so while R goes up, the increasing \$R\$ also limits the maximum current \$I\$ that the batteries can supply. Most batteries1 are designed to be safe under any of these conditions.
However, if you mix fresh and dead batteries, then you have the fresh battery which can deliver a large current, into a dead battery which has a high resistance. This results in excessive heat in the dead battery, which may then be damaged or fail, perhaps spectacularly.
1: but certainly not all batteries. Lithium ion batteries, somewhat infamously are not safe when shorted.
Phil Frost
  • 56,804
  • 141
  • 262
    Awesomely put! Thanks. The R -> "short-circuit current" made it all make sense. – Coldblackice Apr 28 '14 at 22:19
    To make matters worse, short-circuit heat build-up within a cell is often limited by the fact that rapid current drain will cause a battery's internal resistance to increase, but if one has a series stack of batteries, the internal resistance will have to operate over the stack voltage, not over the battery's own voltage. For example, if one has a stack of eight D cells (assume 1.50 volts for simplicity), five of which are fresh and the other of which has a 3ohm series resistance (which would normally limit short-circuit current to 0.5 and power to 0.75W), and... – supercat May 11 '15 at 16:19
    ...one connects the stack to a 6-ohm load (which would limit current to 2 amps from fresh batteries--high but not unreasonable). With the wimpy cell in the circuit current would drop to 1.333 amps, but power dissipation in the weak cell would be 5.333 watts--seven times as much as what it would be if the dead cell were shorted. If heat causes the dead cell's resistance to increase to 6 ohms, that would increase power dissipation even more--to 6 watts (the other batteries wouldn't even get warm, so their resistance wouldn't increase). – supercat May 11 '15 at 16:26
  • You had written Awesome without being a chemist! +1 – Moons May 14 '19 at 10:20
  • But would it be ok to put an older li-on pack in parallel within a new one? Seems like that wouldn't have the problems you describe. – Jonah Jul 31 '21 at 17:33
  • @Jonah consider just the two batteries, without the rest of the circuit. "you have the fresh battery which can deliver a large current, into a dead battery which has a high resistance." – Phil Frost Jul 31 '21 at 23:43
  • @Phil Frost what if the two battery packs are always charged and discharged in parallel? Then there shouldn't be any delivering of current between the two batteries, right? – Jonah Aug 01 '21 at 02:50
  • @Jonah maybe, but then you aren't really mixing new and old batteries. – Phil Frost Aug 01 '21 at 21:18
The worst thing you can do to just about any kind of battery, whether rechargeable or not, is to push an amount of current through it which is large relative to its short-circuit current. As a battery gets depleted, its short-circuit current--and thus the level of current which it can safely handle--will diminish. If all batteries in a stack get depleted at the same time, the amount of current flowing in the system will remain below the amount of current that the weakest battery can safely handle. If, however, one of the batteries in the stack is depleted while other batteries remain strong, the strong batteries may manage to push significant current through the weak one even when its short-circuit current has diminished to basically nothing. Such abuse will severely degrade the useful life of rechargeable batteries, and may cause non-rechargeable batteries (or even rechargeable ones) to release corrosive gunk.
supercat
  • 45,939
  • 84
  • 143
Duracell say: -
Q. Can I mix old and new batteries? A. Do not mix old and new batteries. Doing so will reduce overall performance and may cause battery leakage or rupture. We recommend replacing all batteries within a device.
Q. Can I mix different battery types? A. No, different batteries are designed for different purposes. Mixing a lithium battery with an alkaline battery will not improve device performance. In fact, it will reduce performance and may even damage your device or cause battery leakage or rupture.
As well, do not mix different battery brands within a device. Doing so will reduce overall performance and may also cause battery leakage or rupture. We recommend using the same type of batteries within a device.
Q. Do I have to change all the batteries at the same time? A. We do recommend changing all batteries in a unit at the same time. A partially used battery will drain energy from a new one, reducing the total amount of battery power available.
These questions and asnwers can be found here
The trouble is that Duracell are likely (it's in their interest) to put a less than glossy spin on mixing batteries but it's hard to find a general answer that would contradict.
My own experience of battery failure is limited to NiCd batteries where one cell reversed its polarity effectively dropping the stack of cells from 6.0V to 3.6V and this was due to heavy discharge by a faulty circuit not a random selection of new and old batteries but the liklihood of cell reversal (I heard) was more if you did mix old and new.
If you use old battery with new battery then it harmful for new batteries. Battery power is not constant and reduce the new battery power too.
