int colum01 = B00000000;
int colum01d2 = B00000000;
int colum02 = B00000000;
int colum02d2 = B11111111;
int colum03 = B00000000;
int colum03d2 = B00000000;
int colum04 = B00000000;
int colum04d2 = B00000000;
int colum05 = B00000000;
int colum05d2 = B11111111;
int colum06 = B00000000;
int colum06d2 = B00000000;
int colum07 = B00000000;
int colum07d2 = B00000000;
int colum08 = B00000000;
int colum08d2 = B11111111;
int colum09 = B00000000;
int colum09d2 = B00000000;
int colum10 = B00000000;
int colum10d2 = B00000000;
//Port D = (digital pins 0 to 7)
//Port B = (digital pin 8 to 13)
const int datarowPin = 2; // Port D2
const int latchrowPin = 3; // Port D3
const int clockrowPin = 4; // Port D4
const int datacolumPin = 5; // Port D5
const int latchcolumPin = 6; // Port D6
const int clockcolumPin = 7; // Port D7
const int datacornerPin = 8; // Port B0
const int latchcornerPin = 9; // Port B1
const int clockcornerPin = 10; // Port B2
int rijtijdms = 1000;
void setup () {
pinMode(datarowPin, OUTPUT);
pinMode(latchrowPin, OUTPUT);
pinMode(clockrowPin, OUTPUT);
pinMode(datacolumPin, OUTPUT);
pinMode(latchcolumPin, OUTPUT);
pinMode(clockcolumPin, OUTPUT);
// Alle registers leeg
PORTD &= ~(1<<3); // Set latchrowPin low
PORTD &= ~(1<<6); // Set latchcolumPin low
// Datapins low
PORTD &= ~(1<<2); // Set dataPin high
PORTD &= ~(1<<5); // Set dataPin low
// Clear registers
PORTD &= ~(1<<4); // Set CLK low
PORTD &= ~(1<<7); // Set CLK low
PORTD ^= 1<<4; // Toggle CLK port high
PORTD ^= 1<<7; // Toggle CLK port high
void loop () {
//rij 1
//PORTB &= ~(1<<1); // Set latchcornerPin low
// Kolommen
ShiftOutColum(colum01);
ShiftOutColum(colum01d2);
// Rijen
PORTD |= 1<<2; // Set dataPin high
PORTD |= (1<<6); // Set latchcolumPin high
PORTD |= (1<<3); // Set latchrowPin high
delayMicroseconds(rijtijdms);
//rij 2
// Kolommen
ShiftOutColum(colum02);
ShiftOutColum(colum02d2);
// Rijen
PORTD &= ~1<<2; // Set dataPin low
//rij 3
// Kolommen
ShiftOutColum(colum03);
ShiftOutColum(colum03d2);
// Rijen
//rij 4
// Kolommen
ShiftOutColum(colum04);
ShiftOutColum(colum04d2);
// Rijen
//rij 5
// Kolommen
ShiftOutColum(colum05);
ShiftOutColum(colum05d2);
// Rijen
//rij 6
// Kolommen
ShiftOutColum(colum06);
ShiftOutColum(colum06d2);
// Rijen
//rij 7
// Kolommen
ShiftOutColum(colum07);
ShiftOutColum(colum07d2);
// Rijen
//rij 8
// Kolommen
ShiftOutColum(colum08);
ShiftOutColum(colum08d2);
// Rijen
//rij 9
// Kolommen
ShiftOutColum(colum09);
ShiftOutColum(colum09d2);
// Rijen
//rij 10
// Kolommen
ShiftOutColum(colum10);
ShiftOutColum(colum10d2);
// Rijen
void ShiftOutColum(int data){
for(int i = 0; i < 8; i++) {// step from bit 0 to 7
if ((data >> i) & 0x1 == 1) {//// Check the content of this data bit
PORTD |= 1<<5; //Set bit high
else {
PORTD &= ~(1<<5); //Set bit low
PORTD ^= 1<<7; // Toggle CLK port low
void ShiftOutRow(int data){
for(int i = 0; i < 8; i++) {// step from bit 0 to 15
PORTD |= 1<<2; //Set bit high
else {
PORTD &= ~(1<<2); //Set bit low
PORTD ^= 1<<4; // Toggle CLK port low
The project:
It s supposed to be be a clock that displays the actual time words. This type of clock is available on the internet. Many may know it.
The setup:
The system consists of an 11 colum by 10 row system of 5050 LEDS. So each LED has 3 emitting diodes in it.
Each row is switched on/off by an BD135 transistor. Each colum is switched of by an BC547 transistor. All transistors (21 in total) are switched by 4 74HC595 IC's.
In each colum there is a potentiometer to adjust brightness of the LEDS. The power source is a small power.
The shiftregisters are filled by an arduino UNO.
Please find the attached schematic
The program:
- The pogram first fills the colums with data (for the first row).
- Then switches on the first row.
- Delay of 1 ms.
- Switch of rows and colums
- Fill colums with data (for second row).
- Switch on second row
- Delay, and so on
For test puroses I made a program that is supposed to show only the first 8 LEDS (colums) of the 2nd, 5th and 8th row (program above).
The problem:
The first 8 colums of the 2nd, 5th and 8th row are indeed lighting up bright. However the first 8 LEDS of the 1st, 3rd and 7th row are also lighting up faintly (glowing). The same happens to the last 3 LEDS (colums) of the 2nd, 5th and 8th row, but a littlebit brighter. This is an unwanted effect as it will destroy the eventual performance of the clock. Only the LEDS that I want to light up should light up.
I read this Learning Multiplexing with LEDs, transistor switching speeds thread, but I do seem to have the opposite. The row before the one that is actually lit is glowing. Any help is highly appreciated.
My schematic:
