I get that if you put a resistor in series with a capacitor and add DC voltage, the cap will take longer to charge up.
How can I calculate, how long it takes for the capacitor to charge up/discharge with the given capacitance and resistance and how can I calculate the voltage at a given time?
Chetan Bhargava
  • 4,612
  • 40
skyler
  • 10,136
  • 80
  • 130
  • Did you try searching on Google or Wikipedia? – Kevin Chen Jun 09 '13 at 05:09
  • This probably isn't an exact duplicate, but the following question is very similar and has good answers: http://electronics.stackexchange.com/questions/4951/how-do-i-calculate-how-fast-a-capacitor-will-discharge – PeterJ Jun 09 '13 at 12:42
  • Its a very basic thing about the capacitor for which you get so many materials to go through. Just try searching on the net else go for few basic electronics books where you will get a clear understanding on the capacitor and its related equations. – IamDp Jun 09 '13 at 14:38
  • +1 to counteract someones downvote. It's a better Q than that. –  Jun 11 '13 at 01:50
The voltage across a capacitance \$C\$ at time \$t\$, which was initially at voltage \$V_0\$, which is discharging through a resistance \$R\$, is given by:
$$ V(t) = V_0 e^{\frac{-t}{RC}} $$
Charging a capacitor with a battery of voltage \$V_b\$ through a series resistor is similar:
$$ V(t) = V_b(1-e^{\frac{-t}{RC}}) $$
From these equations, you can see as time goes on, the capacitor voltage approaches its final value (\$0V\$ for discharging, \$V_b\$ for charging) but never reaches it. So, if you want to know how long it takes to (dis)charge, you first have to decide at what point to call the capacitor (dis)charged.
Let's say we want to define 99% discharged as "discharged". How long will this take? Say we had a capacitor charged to \$1V\$; when it is "discharged" it will be at \$0.01V\$. We can substitute these values into the first equation and solve for \$t\$:
$$ 0.01V = 1V\cdot e^{\frac{-t}{RC}} $$
$$ \require{cancel} \frac{0.01\cancel{V}}{\cancel{1V}} = e^{\frac{-t}{RC}}$$
$$ ln(0.01) = \frac{-t}{RC} $$
$$ -ln(0.01) RC = t $$
$$ 4.6 RC \approx t $$
\$RC\$ is the time constant, so this tells us that after about 4.6 time constants, the capacitor will be 99% discharged. The same is true for charging.
Phil Frost
  • 56,804
  • 141
  • 262
