I'm connecting 2 MSP430F5529-based boards (running at 1 MHz) using UART and MAX3232 (MSP430F5529 -> MAX3232 -> cable, a few cm long - will be longer in our final application -> MAX3232 -> MSP430F5529).
It works as long as the bit rate of the UART is under 9600 bps. If this is raised, I start getting many errors (usually the MSB is flipped).
If I remove the MAX3232 and connect the boards directly, the problem goes away. It doesn't happen if I loopback, too.
I am running the MAX3232 at 3 V, which the datasheet says is enough:
Transmitter outputs will meet EIA/TIA-562 levels of ±3.7V with supply voltages as low as 2.7V.
What am I doing wrong?
My code on the TX side is:
void UART_Initialize() {
UCA1CTL1 |= UCSWRST;
UCA1CTL0 = UCMODE_0; // UART
UCA1CTL0 &= ~UC7BIT ; // 8 bits, no parity, 1 stop bit
UCA1CTL1 |= UCSSEL_2; // Source 1 MHz
UCA1BR0 = 104; // 104 ~= 9600 bps
UCA1BR1 = 0;
UCA1MCTL |= UCBRS_0 + UCBRF_0; // Modulation
P4SEL |= BIT4 + BIT5;
UCA1CTL1 &= ~UCSWRST;
UCA1IE |= UCRXIE;
void UART_send_data(unsigned char character) {
while (!(UCA1IFG & UCTXIFG));
UCA1TXBUF = character;
unsigned char UART_get_char() {
while (!(UCA1IFG & UCRXIFG));
return UCA1RXBUF;
void UART_shutdown() {
UCA1IE &= ~(UCRXIE|UCTXIE);
UCA1CTL1 = UCSWRST;
int main() {
unsigned char received_data;
P4OUT = 0x00;
// Disables the watchdog
WDTCTL = WDTPW + WDTHOLD;
// CPU clock to 1 MHz
UCSCTL0 = 0x00;
UCSCTL1 = DCORSEL_3;
UCSCTL2 = FLLN5_L;
__enable_interrupt();
UART_Initialize();
while(1) UART_send_data(0x55);
On the RX side the code is similar except for main()
(which just receives the value and compares to 0x55
