I have a simple robot with two DC motors. Using the L298N Dual H-Bridge, what's the minimum number of control pins I can use to give me forward, back and turn?
Here's a typical setup for the chip. It looks like I'll need 6 control lines to control 2 motors.
If I tied Ven high and relied on the "C=D Fast Motor Stop" when idle would this be bad?
http://letsmakerobots.com/files/userpics/u4107/L298N.png http://letsmakerobots.com/files/userpics/u4107/L298N.png
Toby Jaffey
  • 28,796
  • 96
  • 150
With two pins you have full control. This allows both forward, reverse and stop. if you want to allow coasting, you will need three pins to bring Ven low. If you do not need fast stop, you could use an XOR to control the Ven from the 2 control lines. When they are equal drive t low. Then it has forward reverse and coast.
If you hold Ven High when you decide to stop moving it will full brake. If you use a simple XOR gate to do the Ven signal then you can only coast. It is decided based on what you want the motor to do. If you need the option, use three lines. from a micro this is almost no cost.
Kortuk
  • 13,362
  • 60
  • 85
  • I have a radio module with 4 I/O lines. As you say, it's probably easier to control the H-Bridges properly with another micro and wire the radio into the micro – Toby Jaffey Nov 18 '10 at 16:06
  • That would be an easy way to get any feature you want. – Kortuk Nov 18 '10 at 18:55
  • You could also just add the XOR gate and use two pins and always coast. Do you need to be able to both break and stop? If you do, it is only 3 lines. Although, with 4 lines you could do wireless uart to a micro and get any feature you dream of. – Kortuk Nov 18 '10 at 19:05
The minimum number of pin you need to control is only 'one' per motor, I use this configuration in most of my robot.
Connect a not gate or a transistor to provide inverted the output between C and D pin and supply a PWM signal as a input.
In this setup you'll have only one input controlling both the speed and direction of the motor and comes in very handy in robotics, you can control it by varying the duty cycle.
Direction V/s Duty cycle
stop ----> 50%
forward ----> 51-100% (forward speed increases with increase in duty cycle where 100% as max forward speed)
reverse ----> 0-49% (reverse speed increases with decrease in duty cycle where 0% is max reverse speed)
Zaxx
  • 827
  • This particular technique is called locked anti-phase PWM. The downside is that it does not allow coasting, and a MCU lockup will cause the motors to default to full speed in one direction. – Connor Wolf Nov 18 '10 at 21:35
  • The alternative control technique, which uses two pins (Direction and PWM) is called Sign-Magnitude. – Connor Wolf Nov 18 '10 at 21:37
