Consider the following system:
Digital RGB interface
where:
  • The motherboard contains a LCD controller (SSD1963 from Solomon Systech) and other components (application processor, solenoid drivers, power supplies, etc.)
  • The display board contains a white LED backlight driver and re-route LCD signals.
  • The TFT LCD (AA050MC01 from Mitsubishi) has a digital RGB interface (24-bit of data).
  • The pixel clock frequency is set to 30MHz.
  • The electrical ground cannot be connected to the chassis ground.
I would like to reduce radiated noise and improve noise immunity at a maximum in order to pass EMC compliance tests and therefore I need your advices. For your information, I did EMC tests on the first prototypes which showed a few peaks near 70MHz and between 100MHz and 200MHz that overlap the pattern by ~5dB. Refer to my other post for an analysis of one of these peaks.
Question 1
How can I calculate (or estimate) the required source terminator resistance of the RGB interace signals if I don't know the LCD controller output impedance nor the FFC cables characteristic impedances?
Is a source termination sufficient in this case or should I use other termination techniques?
Question 2
What kind of noise suppression filters should I add and where (on the motherboard only, on both cards, etc.)? Shall I prefer ferrite beads or capacitor type filters?
johsey
  • 358
    Q1 you can estimate but this means getting the cable details such as insulation thicknesses, wire diameters etc. You could look at the signals and try different values of terminating resistance to minimize overshoot on the waveforms. Are you sure that a lack of correct terminating resistors is causing your non-compliance? – Andy aka May 02 '13 at 14:37
  • It seems more likely that the cables are radiating a common-mode signal that originates elsewhere on the motherboard. Try a common-mode ferrite choke that wraps around the flat flex near the motherboard connector. – Dave Tweed May 02 '13 at 15:02
  • @Andyaka As you can see in my "other post", the pixel clock is far from a square wave. Honestly, I have no other explanation than a nonexistent terminating resistor. – johsey May 02 '13 at 15:46
  • @DaveTweed During EMC tests, we tried to add a ferrite core around the long FFC cable near the motherboard connector without success. – johsey May 02 '13 at 16:06
    OK I went back to the previous post and I have to ask this: How much of that post is still relevant? Are the clocks still looking like they were? If so, how can the LCD possibly work? I have a suspicion you are not using the scope probe correctly - for it to be that bad and for you to question the actual clock frequency means that if it still works then you are not measuring the true picture and, if you aren't then your diagnosis as to what is causing EMC is based on no premises that I can fathom. If the scope paints a picture that looks this bad it can't be operational. – Andy aka May 02 '13 at 18:17
  • @Andyaka That post is still relevant. I tried to measure this signal by reducing the ground connection of the probe, by ensuring that the probe was well calibrated but this signal remains the same. As you suggest, I think that this is not the true picture of the signal since the LCD is working. – johsey May 03 '13 at 08:10
    @johsey - I concur - it can't be the true picture or it won't work. You've got to move on to solve the EMI issue but what can you trust? Obviously not the scope/lead - a lot of solving these types of problems are suck it and see but i wouldn't labout over the load terminations - it's the speed of the edges that cause problems not whether they are reflected back up the cable or not. – Andy aka May 03 '13 at 09:42
Answer 1: If you don't know anything about the impedances I would always use series termination in the range between 50 and 100 ohms. Which value you choose is not that critical, but as a rule of thumb: When the communication still works with a higher value, choose that. EMI is caused by reflection due to impedance mismatching. The intended Signal will have to flow through the series terminator only once, whereas a reflection will have to do this at least twice causing it to shrink. So series termination is no reflection prevention but an effective and easy way of reducing it.
Don't try to attach an oscilloscope to evaluate signal integrity, since this will significantly influence the signals.
Answer 2: The frequencies you mentioned can be suppressed using ferrite beads. If space is no constraint, try the one you can wrap around FCC cables.
Power lines should be buffered with capacitors on both boards, make sure to use caps that are fast enough. It is common practice to parallel multiple caps (say 3x100nF) to reduce ESR.
If you still have problems with the clock you can try to add a low-pass at about the clock frequency before feeding it to the cable and restore/buffer the clock at the sink board if necessary.
Simon
  • 685
