I'm trying to track down a VSWR issue with a RF power amplifier (25 W, 150 MHz). The radio we're using to drive it has a VSWR alarm, which triggers during transmit. Older manufacture runs of the PA don't trigger the VSWR alarm, and I'm not certain that the bill of materials used to build the current manufacture run is correct.
I've entered the power amplifier input circuit to an online Smith chart tool (https://www.will-kelsey.com/smith_chart/) and it shows me the input impedance is nothing like 50 Ω. Given my inexperience with this type of tool, and the experience of the engineer who designed the amplifier, it's more likely an error on my part than on the part of the original designer. I want to confirm that I'm using the tool correctly before I dive in and make wholesale changes.
Here is the input circuit. During transmit TR5 switches current through L3-D9-L11-D11, so I've modelled D9 & D11 as shorts. The input impedance to IC4 (RA30H131M1) is 50 Ω according to the datasheet. Receive signal comes through L12 / C51-52. RF PA Input Circuit
I modelled the TX detect circuit (D13-TR5) as a 100 pF capacitor in series with 220 Ω to ground, but tried values between 50 Ω and 10 kΩ and didn't see much difference. I left out the 2.2 µH and 1 nF parts as these don't affect the RF performance. This modelled as in an input impedance of 22+16j Ω. I noted that DP5 is close to 50 Ω, If my modelling is correct, then I guess there is a component issue between the input and C34. Smith-Chart model for PA input
So, I have three questions:
  1. Am I making valid assumptions about the operation of the PIN diodes and large value parts?
  2. Am I entering the data correctly into the modelling tool (e.g. correct order left-to-right)?
  3. What is a suitable model for the TX detect Circuit - This has significant effect on the impedance (but I don't think this is the main cause of the mismatch I'm seeing).
As always, Any help is appreciated.
winny
  • 13,064
  • 63
harry courtice
  • 596
  • I put the old and new Amplifiers onto a VNA, and they differed significantly. Niether looked anything like the smith chart I got from the online tool. So I guess the answer to either question 1 or to question 2 is "No". – harry courtice Aug 23 '23 at 06:46
Your problem, essentially is that the VSWR is too high and it triggers an error. Any assumption you will take in those modeling simulation won't tell you were is the issue since it will be hidden in the assumption you take. For instance, if you doubt your BOM, maybe they used passive component with different frequency response, your model, won't show you that because you are assuming the component. Therefore, I'd say that this model is a bit useless. To give a parallel, it's like if you add a board that used to work then on the next prod, you used a spice simulation to understand what doesn't work. You won't be able to conclude.
Q1
At those frequencies, I'd say, most likely they don't behave like a short. The impedance they will show will also be power dependent. So I think it's a too broad approximation.
Q2
Yes and no, it really depends what you want to know. Both can be viable. Right now, you are measuring the impedance from your port. I doubt that this is what you want to measure. Your objective is, probably, to match the amplifier to thee rest of your circuit. If so, the impedance of your amplifier should be the conjugate impedance of the rest of your circuit to minimize SWR and reflections.
Q3
As I mentioned in introduction, I doubt that modeling will lead you anywhere (unless I don't understand your issue). So, I wouldn't recommend you to model either. My recommendation would be to use a network analyzer (VNA) to measure the impedance on both direction. You will see instantly which part of your circuit has a mismatch. If you don't have access to a VNA, you might be able to measure SWR with other mean like with an oscilloscope.
Julien
  • 1,717
  • thanks Julien. If my modelling is correct, then I'll go down the path of looking for some difference between the old and new boards. If my modelling is wrong, and the input impedance is actually 50Ω, then I'll start looking elsewhere to track down the problem. Regarding the matching, The input to the PA IC and the input to the circuit are both 50Ω. – harry courtice Aug 23 '23 at 01:37
  • The impedance on your input might not be the same impedance that your amplifier sees. The circuit in between has an impact. The same goes for the output. Of course, if one of the two impedance is off, you will get a good clue that their is an issue. Making your model fit your current board is what I think might be hard to do. Simulation are accurate when you consider all your components. For instance, two 18pF capacitors won't necessarily have the same frequency response. So for models to be accurate, you need to take everything into account, even the PCB itself. – Julien Aug 23 '23 at 01:53
  • I took your advice and did a measurement with a VNA. I was hopeful that at 150MHz the model would be close enough, but it does look nothing like what I got on the VNA. – harry courtice Aug 23 '23 at 07:08
  • This is to be expected. As I mentioned, a simulation model is always dependent on the assumption you take. Your issue might be with a single component, or many components. Such significant variation would lead me to blame the PCB first (at your frequency, I don't see passive being so significantly off). I would try to do other measurement before concluding. I would measure your whole watching circuit in S11,S21,S12 and S22 (while disconnecting the rest of the circuit). If you are able to take measurement of sub part of the circuit, it would be easier to conclude. – Julien Aug 23 '23 at 12:06
I took some measurements on a VNA, and neither the old or the new amplifier looked anything like the output from the online tool. Nevertheless, the old one looks good, but the new one is terrible, so I think I'm going to be swapping parts one-by-one until I find the error.
Original The Old Amplifier
New The New Amplifier
harry courtice
  • 596
