I am observing issues with linear actuator not moving and/or moving very slowly at highest speed setting. I am using a DC linear actuator with a speed control unit and rocker switch to extend and retract the actuator. The application involves dispensing material from a syringe at a controlled rate. The wiring is fairly straightforward and is shown below along with part numbers of components used. To limit the stroke length of the actuator in the extend direction, I am using an external PNP sensor to switch ON/OFF a SPDT relay.
I have noticed a positive voltage (~10V) across output terminals of speed controller unit even when the speed knob is turned all the way OFF.
Any idea why the actuator doesn't move or move slowly at times even at full speed setting?
