I am trying to run some 7 nm simulations with NGSPICE, and I would like to know if my results are believable or not. I am using the ASAP7 transistor model, which I have converted from HSPICE to NGSPICE. I am not interested in completely precise results - as NGSPICE cannot do noise anyways, but it would be good to know if the results are in the ballpark of the HSPICE results or not.
I used the following file (TT - typical/typical, slvt - because that is the standard VT):
https://github.com/The-OpenROAD-Project/asap7/blob/master/asap7PDK_r1p7/models/hspice/7nm_TT_160803.pm
I used NGSPICE-41, which seems to already include the compiled OSDI modules, so I did not need to download and use the OpenVAF compiler to get BSIMCMG_va.osdi unlike what the documentation says.
https://gigenet.dl.sourceforge.net/project/ngspice/ng-spice-rework/41/ngspice-41_64.7z
Also in spinit the below line was already commented out:
* unset osdi_enabled
When converting the slvt pmos and nmos models from that file, what needed is to specify TYPE=0/1 in NGSPICE, otherwise it does not work.
This is all what is needed to added BTW:
.model BSIMCMG_osdi_P BSIMCMG_va (
+ TYPE = 0
After conversion, running the simulation results in the following warnings:
  .model bsimcmg_osdi_n bsimcmg_va ( type=1 version=107 bulkmod=1 igcmod=1 ...
unrecognized parameter (version) - ignored
unrecognized parameter (coremod) - ignored
unrecognized parameter (capmod) - ignored
unrecognized parameter (nseg) - ignored
unrecognized parameter (etaqm) - ignored
I compared the values from 7nm_TT_160803.pm to the following file from ngspice-41_64.7z: ngspice-41_64\Spice64\examples\osdi\bsimcmg\Modelcards\modelcard.pmos
  1. version is completely understandable, as the models were made by different companies.
  2. coremod/capmod is understandable, they are missing from modelcard.pmos, and they are set to 0 anyways.
  3. nseg/etaqm can be found in both files with the same values, so why it has not been deleted from modelcard.pmos is a mistery, but whatever.
However, there are a lot of small and some big differences which I do not understand, and they might make the simulations completely different relative to HSPICE:
  1. small differences which might be because the node differences (ASAP7 right):
at=0.0008234 / at=0.001
cgdo=1e-10 / cgdo=1.6e-10
cgso=1e-10 / cgso=1.6e-10
dsub=0.5 / dsub=0.24
dvt0=0.05006 / dvt0=0.05
dvt1=0.4 / dvt1=0.36
eot=2.1e-9 / eot=1e-9
eta0=0.03952 / eta0=0.094
hfin=3e-8 / hfin=3.2e-8
igt=3.5 / igt=2.5
phig=4.678 / phig=4.9278
ptwg=6.322 / ptwg=25
ptwgt=0.0015 / ptwgt=0.004
rdsw=190.6 / rdsw=200
tgidl=-0.01 / tgidl=-0.007
u0=0.02935 / u0=0.0237
ua1=0.00134 / ua1=0.001032
vsat=48390 / vsat=60000
  1. small differences where ASAP7 uses 0, I guess they decided not to simulate these.
cfd=0.2e-10 / cfd=0
cfs=0.2e-10 / cfs=0
deltawcv=-1e-8 / deltawcv=0
dlc=-9.2e-9 / dlc=0
kt1=0.08387 / kt1=0
prt=0.002477 / prt=0
utl=0.001 / utl=0
  1. small differences where NGSPICE uses 0, maybe the OSDI module does not support them.
ucste=0 / ucste=-0.004775
ute=0 / ute=-1.2
xl=0 / xl=1e-9
So far so good, while I have no idea what these parameters above are, the differences do not seem that huge. But then what about the ones below?
  1. The difference is huge. Is it a problem?
deltavsat=11.56 / deltavsat=0.17
geomod=0 / geomod=1
  1. Only the OSDI in ASAP7 seems to need them, is it a problem?
- / fpitch=2.7e-8
- / l=2.1e-8
- / tfin=6.5e-9
- / toxg=1.8e-9
  1. Only the OSDI in NGSPICE seems to need them, is it a problem?
pclmcv=0.013 / -
Since I have know nothing about these parameters, any information would be good. Or if somebody would run the simulations in HSPICE would be fine as well.
"test1.sp" is a simulation of an inverter train. I ignore the first and last inverters, as the first is driven by a clock with arbitrary slew, and the last does not drive anything. At the 0.35 V half point, the delay is between 2-3 ps, which looks reasonable.
.include 'asap7_TT_slvt.sp'
.global vdd! gnd!
.SUBCKT inv in out
   Npmos  vdd! in out vdd! BSIMCMG_osdi_P
   Nnmos  gnd! in out gnd! BSIMCMG_osdi_N
.ENDS
Vvdd vdd! 0 dc=0.7
Vgnd gnd! 0 dc=0
Vin inv_in 0 pulse (0 0.7 20p 10p 10p 20p 500p)
Xinv1 inv_in inv_x1 inv
Xinv2 inv_x1 inv_out inv
Xinv3 inv_out inv_ignore inv
.tran 0.1p 100p
.control
    run
    set xbrushwidth=3
    plot inv_in inv_x1 inv_out
.endc
.end
"test2.sp" is the same simulations where every inverter drives for other inverters, but the output of 3 of the 4 are ignored. This creates slower transitions as expected. At the 0.35 V half point, the delay is between 6-7 ps, which looks reasonable but I am not a chip designer so who knows?
.global vdd! gnd!
.SUBCKT inv in out
   Npmos2  vdd! in out2 vdd! BSIMCMG_osdi_P
   Nnmos2  gnd! in out2 gnd! BSIMCMG_osdi_N
   Npmos3  vdd! in out3 vdd! BSIMCMG_osdi_P
   Nnmos3  gnd! in out3 gnd! BSIMCMG_osdi_N
   Npmos4  vdd! in out4 vdd! BSIMCMG_osdi_P
   Nnmos4  gnd! in out4 gnd! BSIMCMG_osdi_N
.ENDS
Vvdd vdd! 0 dc=0.7
Vgnd gnd! 0 dc=0
.tran 0.1p 100p
.control
    run
    set xbrushwidth=3
.endc
.end
They both include the common file asap7_TT_slvt.sp:
**** copied from asap7\asap7PDK_r1p7\models\hspice\7nm_TT_160803.pm
** Hspice modelcard
+ TYPE = 0
* .model pmos_slvt pmos level = 72
*                         general                          *
+version = 107             bulkmod = 1               igcmod  = 1               igbmod  = 0
+gidlmod = 1               iimod   = 0               geomod  = 1               rdsmod  = 0
+rgatemod= 0               rgeomod = 0               shmod   = 0               nqsmod  = 0
+coremod = 0               cgeomod = 0               capmod  = 0               tnom    = 25
+eot     = 1e-009          eotbox  = 1.4e-007        eotacc  = 3e-010          tfin    = 6.5e-009
+toxp    = 2.1e-009        nbody   = 1e+022          phig    = 4.9278          epsrox  = 3.9
+epsrsub = 11.9            easub   = 4.05            ni0sub  = 1.1e+016        bg0sub  = 1.17
+nc0sub  = 2.86e+025       nsd     = 2e+026          ngate   = 0               nseg    = 5
+l       = 2.1e-008        xl      = 1e-009          lint    = -2.5e-009       dlc     = 0
+dlbin   = 0               hfin    = 3.2e-008        deltaw  = 0               deltawcv= 0
+sdterm  = 0               epsrsp  = 3.9
+toxg    = 1.8e-009
*                            dc                            *
+cit     = 0               cdsc    = 0.003469        cdscd   = 0.001486        dvt0    = 0.05
+dvt1    = 0.36            phin    = 0.05            eta0    = 0.094           dsub    = 0.24
+k1rsce  = 0               lpe0    = 0               dvtshift= 0               qmfactor= 0
+etaqm   = 0.54            qm0     = 2.183e-012      pqm     = 0.66            u0      = 0.0237
+etamob  = 4               up      = 0               ua      = 1.133           eu      = 0.05
+ud      = 0.0105          ucs     = 0.2672          rdswmin = 0               rdsw    = 200
+wr      = 1               rswmin  = 0               rdwmin  = 0               rshs    = 0
+rshd    = 0               vsat    = 60000           deltavsat= 0.17            ksativ  = 1.592
+mexp    = 2.491           ptwg    = 25              pclm    = 0.01            pclmg   = 1
+pdibl1  = 800             pdibl2  = 0.005704        drout   = 4.97            pvag    = 200
+fpitch  = 2.7e-008        rth0    = 0.15            cth0    = 1.243e-006      wth0    = 2.6e-007
+lcdscd  = 0               lcdscdr = 0               lrdsw   = 1.3             lvsat   = 1441
*                         leakage                          *
+aigc    = 0.007           bigc    = 0.0015          cigc    = 1               dlcigs  = 5e-009
+dlcigd  = 5e-009          aigs    = 0.006           aigd    = 0.006           bigs    = 0.001944
+bigd    = 0.001944        cigs    = 1               cigd    = 1               poxedge = 1.152
+agidl   = 2e-012          agisl   = 2e-012          bgidl   = 1.5e+008        bgisl   = 1.5e+008
+egidl   = 1.142           egisl   = 1.142
*                            rf                            *
*                         junction                         *
*                       capacitance                        *
+cfs     = 0               cfd     = 0               cgso    = 1.6e-010        cgdo    = 1.6e-010
+cgsl    = 0               cgdl    = 0               ckappas = 0.6             ckappad = 0.6
+cgbo    = 0               cgbl    = 0
*                       temperature                        *
+tbgasub = 0.000473        tbgbsub = 636             kt1     = 0               kt1l    = 0
+ute     = -1.2            utl     = 0               ua1     = 0.001032        ud1     = 0
+ucste   = -0.004775       at      = 0.001           ptwgt   = 0.004           tmexp   = 0
+prt     = 0               tgidl   = -0.007          igt     = 2.5
*                          noise                           *
** Hspice modelcard
.model BSIMCMG_osdi_N BSIMCMG_va (
+ TYPE = 1
* .model nmos_slvt nmos level = 72
*                         general                          *
+eot     = 1e-009          eotbox  = 1.4e-007        eotacc  = 1e-010          tfin    = 6.5e-009
+toxp    = 2.1e-009        nbody   = 1e+022          phig    = 4.2466          epsrox  = 3.9
+l       = 2.1e-008        xl      = 1e-009          lint    = -2e-009         dlc     = 0
+toxg    = 1.80e-009
*                            dc                            *
+cit     = 0               cdsc    = 0.01            cdscd   = 0.01            dvt0    = 0.05
+dvt1    = 0.47            phin    = 0.05            eta0    = 0.07            dsub    = 0.35
+k1rsce  = 0               lpe0    = 0               dvtshift= 0               qmfactor= 2.5
+etaqm   = 0.54            qm0     = 0.001           pqm     = 0.66            u0      = 0.0303
+etamob  = 2               up      = 0               ua      = 0.55            eu      = 1.2
+ud      = 0               ucs     = 1               rdswmin = 0               rdsw    = 200
+rshd    = 0               vsat    = 70000           deltavsat= 0.2             ksativ  = 2
+mexp    = 4               ptwg    = 30              pclm    = 0.05            pclmg   = 0
+pdibl1  = 0               pdibl2  = 0.002           drout   = 1               pvag    = 0
+fpitch  = 2.7e-008        rth0    = 0.225           cth0    = 1.243e-006      wth0    = 2.6e-007
+lcdscd  = 5e-005          lcdscdr = 5e-005          lrdsw   = 0.2             lvsat   = 0
*                         leakage                          *
+aigc    = 0.014           bigc    = 0.005           cigc    = 0.25            dlcigs  = 1e-009
+dlcigd  = 1e-009          aigs    = 0.0115          aigd    = 0.0115          bigs    = 0.00332
+bigd    = 0.00332         cigs    = 0.35            cigd    = 0.35            poxedge = 1.1
+agidl   = 1e-012          agisl   = 1e-012          bgidl   = 10000000        bgisl   = 10000000
+egidl   = 0.35            egisl   = 0.35
*                            rf                            *
*                         junction                         *
*                       capacitance                        *
+cgbo    = 0               cgbl    = 0
*                       temperature                        *
+ute     = -0.7            utl     = 0               ua1     = 0.001032        ud1     = 0
*                          noise                           *
Result of simulation - left 4 inv, right 1 inv
"from 7nm_TT_160803 pm.txt" and "from modelcard pmos.txt" are the parameters from the two different sources, sorted and converted to similar diffable formats. I have uploaded all the files here:
https://drive.google.com/file/d/11-vKHFhfnxR9_VJzYrE4iICk3xOMcqq7/view?usp=sharing
Does this simulation result in reasonable output? Or did I screw up something?
NoiseEHC
  • 95
  • This is a great question, but I suggest asking it as an ngspice support ticket (or post something with a direct link to this question so you don't have to rewrite everything) since you'll get the developers to take a look at it too: https://sourceforge.net/p/ngspice/support-requests/ – Ste Kulov Aug 24 '23 at 16:50
  • Yep:https://sourceforge.net/p/ngspice/support-requests/67/ – NoiseEHC Aug 26 '23 at 02:37
0 Answers0
