Quick background on myself: I work as an engineering tech at a company that manufactures instrument transformers. I assist our technical director with designing transformers, however I do not have an electrical engineering degree and am sort of learning on the job (kind of like an apprenticeship situation).
That being said, we had a customer for whom we were developing a Rogowski coil which was to be assembled in a plastic case and encapsulated. Ultimately they opted for a PCB Rogowski Coil due to size constraints. I found it interesting that this was possible, because I was under the assumption that a turn in a coil had to be a loop of wire around a core (in this case an air core) and i thought this had to do with the core containing an alternating flux which, with the right-hand rule, induces a voltage in the windings that are wound perpendicular to the core. However, in the image below the windings seem to be laid down on top of the PCB ring (air core) rather than as loops of wire.
Rogowski Coil printed on circuit board
Image source: IEEE PSRC Special Report, Practical Aspects of Rogowski Coil Applications to Relaying, September 2010
I'm essentially curious as to what really constitutes a turn in a coil geometrically? Is it any conductor on a core that is normal to the ID and OD (and therefore perpendicular to the flux) whether its a loop around the core or if it's zig-zagged like as shown in the picture above?
SamGibson
  • 17,231
  • 58
Tbure90
    Tbure90 - Hi, (a) As you're new here, please see the [tour] & [help] for the main rules. (b) Please note the [site rule](/help/referencing) which requires that when a post includes content (e.g. text, image, photo etc.) copied or adapted from elsewhere, that copied content must be correctly referenced. As a minimum, the source webpage or PDF etc. should be linked (see that rule regarding references for books / articles etc.). In order to help you, I found what I believe to be the source PDF link & added it for you. For the future, please remember it's your responsibility to do that :) Thanks. – SamGibson Aug 14 '23 at 21:05
  • Why do you think there are no loops? Is that a two layer PCB? Rogowski coils are not exactly traditional transformers, and so called planar Rogowski coils can be manufactured on a PCB - just adding proper terms if someone wants to write an answer. – Justme Aug 14 '23 at 21:12
  • From what i understand, it's a single layer PCB. My assumption was that a turn (loop) was a conductor wound around a core, not along a core which is what the image shows. – Tbure90 Aug 14 '23 at 21:20
  • what's on the back side of the board? – jsotola Aug 14 '23 at 21:24
  • @jsotola looks like nothing on the back, just more board. – Tbure90 Aug 14 '23 at 21:29
  • That's a nice technique for automating the 'winding' of a very controlled geometry 'air' core. – Neil_UK Aug 15 '23 at 04:45
You're asking the right questions, and honestly, you're reading the texts you have very thoroughly, so that's really a good thing!
The publication you found is wrong about this being single-sided.
Because it doesn't cite the sources for its pictures (which is a big bad thing for a "report"-style publication), one can't verify the claims it makes. That sadly disqualifies the publication as whole. We need to treat all it says with solid scepticism!
Let's, however, really look at this thing in detail:
Schematic view
Here, you see the two separate strings of conductors: the "black" ones, and the white ones. They're actually the same string, connected at the right end
My hypothesis of how they are actually built based on this schematic alone:
The solid parts (green and blue) are on top, the dashed parts (orange and black) below:
colorized
And yeah, that's really just a "PCB substrate-core" winding! If you just drilled holes in a piece of board where the little round dots at the corners are, you could wind this with wire yourself. It'd be the same principle as if you took a plastic rod, laid it straight left-to-right in front of you, wound 7 windings clockwise (looking into the rod from the right) around the rod (blue and black), while going slowly from left to right, then slipped a plastic tube around the rod and continued in the same rotational sense for 7 windings around that slightly larger tube, going slowly from right to left (green and orange). Finally, you'd heat the whole thing until the plastic gets soft and squash it flat.
Let's see whether the photograph in its low resolution corroborates that assumption:
annotated excerpt of the photo
These small silvery-pitted circles really look like typical vias to me, indicating that the trace continues on the backside. If it didn't these would all be short unconnected traces, not a zigzag pattern in sight!
So, yeah, this is not a single-layered board, as the text claims. This is really just proper windings on a PCB substrate core :)
As to the general question of what constitutes a winding: the only part of the windings that gets voltage induced is the length that they are perpendicular to the magnetic field lines; the direction of induced voltage, as you say, depends on relative direction of winding and field lines. The fact that a coil with many windings around a core experiences stronger induction stems from the fact that these windings are all in the same direction relative to the magnetic flux.
When you just zigzag in the same plane that's parallel to the magnetic flux, the alternating lines are in opposing directions, and this cancel out.
You need to have a volume that you enclose. That's the PCB here.
Neil_UK
  • 158,152
  • 173
  • 387
Marcus Müller
  • 88,280
  • 131
  • 237
    @ Marcus Muller To be fair to the paper, the paper is about the relay applications of Rogowski coils not necessarily how they're constructed. They just threw in some images to show examples of different types of coils. But nonetheless, thank you for your explanation! "You need to have a volume that you enclose" is the answer i was looking for! I guess I misinterpreted what I was looking at in that image – Tbure90 Aug 15 '23 at 13:27
