I’m trying to make a controller with 3 H bridges (N-FET, IR2101 and a Arduino Mega). I’m sure that the problem is in my code but I don’t know how to fix it. I think that the problem is in the PWM.The pwm is the same in all phases. AH, BH and CH have the same wave at the same time. This is my code:
#define THROTTLE_PIN A15
#define THROTTLE_MIN 0
#define THROTTLE_MAX 1023
#define HALL_1_PIN 7 // Azul
#define HALL_2_PIN 8 // Verde
#define HALL_3_PIN 4 // Amarelo
#define AH_PIN 9
#define AL_PIN 6
#define BH_PIN 10
#define BL_PIN 5
#define CH_PIN 11
#define CL_PIN 3
#define PWM_MAX_DUTY 255
#define PWM_MIN_DUTY 100
#define PWM_START_DUTY 100
byte motor_speed = 255;//PWM_START_DUTY;
#define HALL_OVERSAMPLE 11
byte motorState = 0;
uint8_t lastHall = 0;
const byte pwmValues[6][6] = {
{0, 1, 1, 0, 0, 0},
{0, 0, 1, 0, 0, 1},
{1, 0, 0, 0, 0, 1},
{1, 0, 0, 1, 0, 0},
{0, 0, 0, 1, 1, 0},
{0, 1, 0, 0, 1, 0},
void setup() {
Serial.begin(115200);
pinMode(AH_PIN, OUTPUT);
pinMode(AL_PIN, OUTPUT);
pinMode(BH_PIN, OUTPUT);
pinMode(BL_PIN, OUTPUT);
pinMode(CH_PIN, OUTPUT);
pinMode(CL_PIN, OUTPUT);
pinMode(HALL_1_PIN, INPUT);
pinMode(HALL_2_PIN, INPUT);
pinMode(HALL_3_PIN, INPUT);
Serial.print("De a primeira binbada no motor");
pinMode(THROTTLE_PIN, INPUT);
uint8_t hall = getHalls();
delay(500);
Serial.print("Primeira posicao do motor: ");
Serial.print(hall);
void loop() {
motor_speed = analogRead(THROTTLE_PIN); // Ler o valor do potenciômetro
// Calcular os ciclos de trabalho para cada fase com base na velocidade do motor
uint8_t dutyCycleA = motor_speed;
uint8_t dutyCycleB = motor_speed;
uint8_t dutyCycleC = motor_speed;
// Definir os ciclos de trabalho PWM para cada fase com um dead time de 10 microssegundos
analogWrite(AH_PIN, pwmValues[motorState][0] * dutyCycleA);
delayMicroseconds(10);
analogWrite(AL_PIN, pwmValues[motorState][1] * dutyCycleA);
analogWrite(BH_PIN, pwmValues[motorState][2] * dutyCycleB);
analogWrite(BL_PIN, pwmValues[motorState][3] * dutyCycleB);
analogWrite(CH_PIN, pwmValues[motorState][4] * dutyCycleC);
analogWrite(CL_PIN, pwmValues[motorState][5] * dutyCycleC);
if (hall != lastHall) {
lastHall = hall;
motorState = calculateMotorState(hall);
// Delay para observar a posição (se necessário)
delay(75);
Serial.print("Sensores Hall: ");
Serial.print(hall);
Serial.print(", Posição do Motor: ");
Serial.println(motorState);
uint8_t calculateMotorState(uint8_t hall) {
if (hall == 1) { // 1
return 1;
} else if (hall == 3) { // 3
return 3;
} else if (hall == 4) { // 4
return 4;
} else if (hall == 5) { // 5
return 5;
} else if (hall == 6) { // 6
return 6;
} else if (hall == 2) { // 2
return 2;
} else {
return 0;
uint8_t getHalls() {
uint8_t hallCounts[] = {0, 0, 0};
for (uint8_t i = 0; i < HALL_OVERSAMPLE; i++) {
hallCounts[0] += digitalRead(HALL_1_PIN);
hallCounts[1] += digitalRead(HALL_2_PIN);
hallCounts[2] += digitalRead(HALL_3_PIN);
uint8_t hall = 0;
if (hallCounts[0] >= HALL_OVERSAMPLE / 2)
hall |= (1 << 0);
if (hallCounts[1] >= HALL_OVERSAMPLE / 2)
hall |= (1 << 1);
if (hallCounts[2] >= HALL_OVERSAMPLE / 2)
hall |= (1 << 2);
return hall & 0x7;
