I am working with an IGLOO2 device and attempting to instantiate a RAM1K18 IP into my design using the SmartDesign Tool in Libero 2023.1. I have a basic testbench in which I establish an address, and attempt to write to it, and read back the data. However, in sim I see both "A_DOUT" and "B_DOUT" all 0's. The "Busy" signal is constant 'z'
I have tried extending my sim to 1ms, which I feel is plenty of time, however the signals remain. I have ported a design onto HW with the same IP using a similar method of writing / reading and am seeing 0's for my DOUT signals there as well though there I see constant '0' instead of constant 'z'.
Testbench snippet:
--Generate the test stimulus
tb1 : process
begin
--Pre reset
wait for CLK_PERIOD*10;
--Toggle reset
wait for CLK_PERIOD*5;
RESET_N <= '0';
wait for CLK_PERIOD;
RESET_N <= '1';
-- First write to testRAM
wait for CLK_PERIOD*100;
A_ADDR <= "00000010000000";
B_ADDR <= "00000011000000";
A_DIN <= "000000000010000000";
B_DIN <= "000000000011000000";
A_WEN <= "11";
B_WEN <= "11";
--Change from wr to rd
A_WEN <= "00";
B_WEN <= "00";
wait for 100 us; --maybe wait a long time?
-- Second write to testRAM
A_ADDR <= "00000100000000";
B_ADDR <= "00000100000000";
A_DIN <= "000000000100000000";
B_DIN <= "000000000100000000";
A_WEN <= "11";
B_WEN <= "11";
-- Change from wr to rd
A_WEN <= "00";
B_WEN <= "00";
--Rd from first address set
Generated Entity from SmartDesign:
-- Created by SmartDesign Wed Jul 19 12:24:41 2023
-- Version: 2023.1 2023.1.0.6
-- Libraries
library ieee;
use ieee.std_logic_1164.all;
library smartfusion2;
use smartfusion2.all;
-- sd_ram1k18 entity declaration
entity sd_ram1k18 is
-- Port list
port(
-- Inputs
A_ADDR : in std_logic_vector(13 downto 0);
A_ARST_N : in std_logic;
A_BLK : in std_logic_vector(2 downto 0);
A_CLK : in std_logic;
A_DIN : in std_logic_vector(17 downto 0);
A_DOUT_ARST_N : in std_logic;
A_DOUT_CLK : in std_logic;
A_DOUT_EN : in std_logic;
A_DOUT_LAT : in std_logic;
A_DOUT_SRST_N : in std_logic;
A_EN : in std_logic;
A_WEN : in std_logic_vector(1 downto 0);
A_WIDTH : in std_logic_vector(2 downto 0);
A_WMODE : in std_logic;
B_ADDR : in std_logic_vector(13 downto 0);
B_ARST_N : in std_logic;
B_BLK : in std_logic_vector(2 downto 0);
B_CLK : in std_logic;
B_DIN : in std_logic_vector(17 downto 0);
B_DOUT_ARST_N : in std_logic;
B_DOUT_CLK : in std_logic;
B_DOUT_EN : in std_logic;
B_DOUT_LAT : in std_logic;
B_DOUT_SRST_N : in std_logic;
B_EN : in std_logic;
B_WEN : in std_logic_vector(1 downto 0);
B_WIDTH : in std_logic_vector(2 downto 0);
B_WMODE : in std_logic;
SII_LOCK : in std_logic;
-- Outputs
A_DOUT : out std_logic_vector(17 downto 0);
BUSY : out std_logic;
B_DOUT : out std_logic_vector(17 downto 0)
end sd_ram1k18;
-- sd_ram1k18 architecture body
architecture RTL of sd_ram1k18 is
-- Component declarations
-- RAM1K18
component RAM1K18
generic(
MEMORYFILE : string := "" ;
RAMINDEX : string := ""
-- Port list
port(
-- Inputs
-- Outputs
end component;
-- Signal declarations
signal A_DOUT_net_0 : std_logic_vector(17 downto 0);
signal B_DOUT_net_0 : std_logic_vector(17 downto 0);
signal BUSY_net_0 : std_logic;
signal A_DOUT_net_1 : std_logic_vector(17 downto 0);
signal B_DOUT_net_1 : std_logic_vector(17 downto 0);
signal BUSY_net_1 : std_logic;
begin
-- Top level output port assignments
A_DOUT_net_1 <= A_DOUT_net_0;
A_DOUT(17 downto 0) <= A_DOUT_net_1;
B_DOUT_net_1 <= B_DOUT_net_0;
B_DOUT(17 downto 0) <= B_DOUT_net_1;
BUSY_net_1 <= BUSY_net_0;
BUSY <= BUSY_net_1;
-- Component instances
-- RAM1K18_0
RAM1K18_0 : RAM1K18
port map(
-- Inputs
A_CLK => A_CLK,
A_DOUT_CLK => A_DOUT_CLK,
A_ARST_N => A_ARST_N,
A_DOUT_EN => A_DOUT_EN,
A_BLK => A_BLK,
A_DOUT_ARST_N => A_DOUT_ARST_N,
A_DOUT_SRST_N => A_DOUT_SRST_N,
A_DIN => A_DIN,
A_ADDR => A_ADDR,
A_WEN => A_WEN,
B_CLK => B_CLK,
B_DOUT_CLK => B_DOUT_CLK,
B_ARST_N => B_ARST_N,
B_DOUT_EN => B_DOUT_EN,
B_BLK => B_BLK,
B_DOUT_ARST_N => B_DOUT_ARST_N,
B_DOUT_SRST_N => B_DOUT_SRST_N,
B_DIN => B_DIN,
B_ADDR => B_ADDR,
B_WEN => B_WEN,
A_EN => A_EN,
A_DOUT_LAT => A_DOUT_LAT,
A_WIDTH => A_WIDTH,
A_WMODE => A_WMODE,
B_EN => B_EN,
B_DOUT_LAT => B_DOUT_LAT,
B_WIDTH => B_WIDTH,
B_WMODE => B_WMODE,
SII_LOCK => SII_LOCK,
-- Outputs
A_DOUT => A_DOUT_net_0,
B_DOUT => B_DOUT_net_0,
BUSY => BUSY_net_0
end RTL;
Zoomed in waveform (initial values & and setting A_WEN to "11" (write en)):
Zoomed out waveform showing no change in busy signal:
I have been using this doc (pages 54 - 61) for reference: https://www.microsemi.com/document-portal/doc_view/130906-smartfusion2-and-igloo2-macro-library-guide
I look forward to your responses and appreciate the help.
