I'm trying to set up code to preload the EEPROM of a PIC16F628A with the necessary data depending on the value of one #define, so the uC is ready to be popped into a PCB and be used without any extra procedure.
This is what I did so far:
__eeprom uint8_t A_RESET[2] = {0x00};
__eeprom uint8_t B_RESET[REMOTEMEM*3] = {0xAE};
__eeprom uint8_t C_RESET[128 - (sizeof A_RESET) - (sizeof B_RESET)] = {0xFF};
In this exapmle, I'll use a REMOTEMEM of 4, so this should be the EEPROM map:
ADDRESS 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 AE AE AE AE AE AE AE AE AE AE AE AE FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
But instead, MPLAB ends up doing this:
00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 AE 00 00 00 00 00 00 00 00 00 00 00 00 00
I have previosuly used to have only one variable type __eeprom, and I had to write all 128 locations of the EEPROM on that variable. I want to avoid that because now I have that REMOTEMEM that can be changed.
brhans
  • 14,373
  • 49
fpp
  • 159
    I don't have any experience with the PIC compiler's `__eeprom` keyword, so I can't comment on that part, but in standard C, initializing an array with a single value, for example your `__eeprom uint8_t B_RESET[REMOTEMEM*3] = {0xAE};` does *not* initialize the entire array with that value - it only initializes the 1st element of the array. The only exception to that is if you initialize with `0`, so your `__eeprom uint8_t A_RESET[2] = {0x00};` is valid. – brhans Jul 29 '23 at 23:24
  • Thanks for the clarification @brhans. I looked up how to do what I wanted and found out about the `{[a ... b] = c}` function in C and it actually works with XC8. Now all the spaces of the array are initialized with the values I want, but they're organized backwards. First, all the `0xFF`s, then the `0xAE`s and at the end the `0x00`s. Do you know any standard way of changing the order of variable creation in memory? Since the EEPROM is not mapped in the memory of the uC, I cannot use `__at()` to fix the arrays in memory. – fpp Jul 29 '23 at 23:44
  • @brhans actually in all cases writing {stuff} initializes the rest of the elements with 0. So it happens that {0} initializes the first element with 0 and the rest with 0 so it does what you want. {0xAE} initializes the first element with 0xAE and the rest with 0. – user253751 Jul 30 '23 at 00:02
    To enforce a particular order you could wrap all 3 arrays in a struct - something like: `__eeprom struct {uint8_t A_RESET[2]; uint8_t B_RESET[REMOTEMEM*3]; uint8_t C_RESET[128 - (sizeof A_RESET) - (sizeof B_RESET)]; } = { {... initializer for A_RESET}, {... initializer for B_RESET}, {... initializer for C_RESET} };` – brhans Jul 30 '23 at 00:10
    @brhans Please sum up all your comments in an actual answer. This is not a forum. The OP can mark it as accepted, if satisfied. – the busybee Jul 31 '23 at 05:58
  • @thebusybee IMO this question is off-topic for EE (as it's almost entirely a programming question), so although I'd like to help the OP I'd rather not make an 'official' answer. – brhans Jul 31 '23 at 12:11
    @brhans Good point, and well understood. Wouldn't it be better to point that out and ask the OP to move, instead of "providing an answer"? Did you vote to close? (My reputation is yet too low to see the votes.) – the busybee Jul 31 '23 at 12:14
I do agree that at its core the question is one about programming language syntax. It does seem more appropriate to ask this specific question in this forum as the members here are more aware of what the poster is trying to implement in an embedded controller.
That said this is how I did it: enter image description here
 * File:   main.c
 * Author: dan1138
 * Target: PIC16F628A
 * Created on August 1, 2023, 11:34 AM
 * See: https://electronics.stackexchange.com/questions/675769/how-can-i-dynamically-preload-the-eeprom-on-a-pic-microcontroller/676147#676147
// PIC16F628A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#pragma config FOSC = INTOSCIO  // Oscillator Selection bits (INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is MCLR)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config LVP = OFF        // Low-Voltage Programming Enable bit (RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EE Memory Code Protection bit (Data memory code protection off)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define REMOTEMEM 4
__eeprom struct {
    uint8_t A[2];
    uint8_t B[REMOTEMEM][3];
    uint8_t C[128-(2+REMOTEMEM*3)];
} EEmem = {.A[0 ... 1]=0x00,
           .B[0 ... REMOTEMEM-1][0 ... 2]=0xAE,
           .C[0 ... 128-(2+REMOTEMEM*3)-1]=0xFF
void main(void)
    volatile static uint8_t Index, CheckSum;
    for(;;)
        CheckSum = 0;
        for(Index = 0; Index < 128; Index++)
            CheckSum += ((__eeprom uint8_t *)(&EEmem))[Index];
Dan1138
  • 1,294
  • Why do you use volatile and static on the local variables in the main function? – Oskar Skog Aug 02 '23 at 07:28
  • @OskarSkog, Because the XC8 optimizer is aggressive I use the volatile storage class to trick the compiler into generating code for the main loop. – Dan1138 Aug 02 '23 at 19:32
