I am looking at the schematic of the DRV8434SEVM evaluation board for the DRV8483S stepper motor driver and I see they've put these 3.3nF capacitors on the outputs going to the stepper motor coils. I cannot find any mention about doing this in the datasheet of the driver or anywhere else, why might you want to do something like this? outputs
The printed (PDF) schematic shows these are DNP (do not place), so it seems a non-issue.
Perhaps they are available as an option to slow edge rate from the inverters.
I wouldn't recommend it myself; it's a crude method that increases switching loss.
Better is a series inductive element (which limits current drawn from the inverter, thus having less impact on efficiency), placed before the capacitor, with damping provided either by using a lossy inductive element like a ferrite bead, or an R+C in parallel with the C.
Tim Williams
  • 22,874
  • 71
