I have some valves (Walfront36atn8w5ph) I need to control. They use pulses of +5V and -5V, with up to 1A current (specified, not personally measured), to change state (no holding current/voltage, it's just about initiating a state change). Some documentation says the valve is "normally closed", but testing seems to show it just holds its current state.
Ideally, I would control them with an NI board or an Arduino. I will refer to Arduino going forward, since I think more people have experience with those.
The valves should switch state, in opposite directions, simultaneously. A delay is acceptable, and timing is not critical. They will be providing pressure and vacuum to the same line.
I had intended to use separate 5V differential supplies wired up in series and to gate transistors to activate them. I also considered using a 12V differential supply and a voltage divider, to get the proper range.
The initial thought was to just attach a transistor to each valve. To begin with, there's an issue with the gate-to-source voltages and the Arduino, necessitating the voltage divider on the gate for the -5V side.
I feel like there might be something simpler and more clever. Would relays be the right way to go about this? If so, what's the simplest configuration, using the fewest number of control channels?
Initial testing doesn't suggest that the valves will require any sort of pull-up/pull-down resistors, but I do wonder if that might be a more correct design. Will I need to add flyback diodes? Given the biasing, I'm not sure how that would work.
I'm open to buying parts, but I have a variety of acceptable MOSFETs (IRLD024, IRLD120), and some op-amps and comparators, if necessary.
Also, I was hoping to keep this compact and had originally intended to fit everything on a generic 1"x1" breadboard PCB. The solution is getting rather complicated for the footprint, as I will need to fit a few of these onto the same board, along with some other unrelated parts (resistors and connectors).
I just started looking at other valve options and found the US Solid normally closed (JFSV00065), which might simplify things a bit. But, I don't like that they aren't rated for continuous operation. I expect to keep a valve open for an hour or two at a time and for ~4 sessions per day. So, while this comes in under their 8 hour operational limit, it is a little disconcerting.
This seems like it would be a common issue, since many valves work similarly. The other questions I looked at on here don't seem to address both the switching and polarity.
TwoValve_Unipolar As you can see, that would allow me to open valve 1 (+5V pulse), but never to close it (-5V pulse), and vice-versa for valve 2.
SingleValve_BipolarUnconnected While this creates the correct voltages, there isn't a clear way to get them connected to the valve without jumping through a bunch of hoops.
enter image description here I like the relay a bit more, because the referencing is simplified. But, there's no state in which 0V is applied to a valve. I think the nominal state should be 0V, there's no need to be constantly driving current into the device. The switching time is relatively short and the vast majority of the time will be spent at rest in a given state. And, yes, I know I do not need to connect the ground all the way to the power supplies, but I thought doing so made things more obvious in the schematic.
    This might be a job for a full H-bridge DC motor driver chip. This would need only one 5 V supply. – Jens Jul 21 '23 at 20:54
The usual way to control bi-directional (latching) relays or valve coils is with an "H-bridge", which may be visualised like this:
Current direction through the coil (and therefore polarity of voltage across it) is controlled by opening and closing pairs of switch elements, SW1/SW4 and SW2/SW3. The switches themselves can be realised with BJTs or MOSFETs, which might look something like this:
simulate this circuit
Note that M1 and M3 are P-channel devices, while M2 and M4 have N channels. The diodes are there to direct current around the transistors, protecting them from the enormous EMF generated when the coil gets switched off. R1 and R2 keep gate current down to 10mA or so during transitions, so the Arduino's outputs aren't stressed.
This simplistic approach only works it the supply voltage to the bridge (+5V) is equal to the logic high potentials (also +5V, provided by the Arduino outputs in your case). All MOSFETs will require \$V_{GS(TH)} < 3.5V\$, so that they will switch fully with 5V/0V Arduino output potentials.
In this example, with A low (0V), and B high (+5V), the transistors are in a state resembling the top left switch circuit, and with A high and B low, the state would be represented above right. When A and B have the same state (both high, or both low), then the coil is effectively short circuited, and no coil current flows (except briefly while the coil's magnetic field collapses).
This is a very simplistic design, and typically you would also find many peripheral elements to take care of various issues such as shoot-through; we don't often see such a bare-bones implementation. Because such bridges are a common requirement, and are often difficult to get right, there exist dedicated ICs that implement them, such as the L293 or L293D. This particular IC has four half-bridge (push-pull pairs like M1 and M2), allowing you to operate 2 valves with a single IC.
However, your speed requirements are modest (no PWM, for example), and with such a low supply potential difference, it's unlikely that both FETs will switch on simultaneously, so the above design might work for you as shown.
In any case, IC or discrete, do not forget to bypass the supply with capacitors across (and very close to) the bridge's +5V and ground power supply nodes.
Simon Fitch
  • 27,759
  • 87
