I need to send some SCPI to a power supply IT6000C.
Part of the code is to check if the instrument is in over voltage protection (OVP) or current protection (OCP).
I don’t manage to find a SCPI Command to control it. I have found only SYSTem:ERRor? (at page 249 of the user’s manual), but it return always 0 (no error) even if the instruments in error.
Surfing in internet, it should be quite easy and the command is standard. I wonder if I have to do something more.
JYelton
  • 32,302
  • 134
  • 249
    My experience is that instruments from companies other than Keysight/Tek/NI often take a fairly fast & loose approach to implementing SCPI. It might just be that your instrument is not standard compliant. A link to its manual might help us give you a more useful answer. – The Photon Jul 13 '23 at 15:50
  • @ThePhoton Exactly- Even Keysight and Tek can vary greatly between revisions and generations. Second and third tier instruments are all over the place. – John D Jul 13 '23 at 20:58
the user's manual is possible to get from the following link.
https://eur.itechate.com/en/info_128.aspx?itemid=416&lcid=84
Thanks in advance Fausto
  • Can you please explain the system command in this answer if the link goes down this answer will be worthless – Voltage Spike Jul 17 '23 at 15:19
  • Horrible website (https://i.stack.imgur.com/y2DMO.png). I don't mind the bad grammar so much, since they're from CN. But clicking on 'No, thanks' does nothing. A product has to be REALLY amazing, that I'm willing to create an account just to read the user's manual. – Velvel Jul 17 '23 at 15:56
