I have a SystemVerilog module that I want to test using assertions. For simplicity let's say the DUT is this:
module dut (
    input logic [7:0] da
    output logic [7:0] db
    always_comb begin:
        if (da == '0)
            db <= '1;
        else
            db <= '0
    end
endmodule
I have also created a file containing a module with the assertions for the DUT:
module properties(
    input logic [7:0] pa,
    input logic [7:0] pb
    always_comb begin:
        assert final (pa == pb) $error("assertion failed"); else $display("PASS");
    end
endmodule
And finally I have a test bench:
module tb();
    logic [7:0] ta;
    logic [7:0] tb;
    dut dut_inst(.da(ta), .db(tb));
    bind dut_inst properties dut_bind(.pa(da), .pb(db));
    initial begin:
       // do something here...
    end
endmodule
The problem: When compiling the code I get two errors from Quartus :
  • The first one is about the properties module and says: Error (10170): Verilog HDL syntax error at properties.sv(6) near text: "final"; expecting "(". If I remove the final keyword the error goes away but I must use final to filter out simulation glitches.
  • The second one says Error (10170): Verilog HDL syntax error at tb.sv(8) near text: "bind"; expecting "endmodule".
What I have tried so far
Regarding the first issue I only tried to remove the final keyword but it is not a solution as I said before.
For the second error, I tried binding this way:
bind dut properties dut_bind(.pa(da), .pb(db));
but I get the same error. I also tried moving the bind out of the tb module like that:
module tb();
    logic [7:0] ta;
    logic [7:0] tb;
    initial begin:
    end
endmodule
but I got a similar error saying Error (10170): Verilog HDL syntax error at tb.sv(8) near text: "bind"; expecting a description. What am I doing wrong?
PS: I am using intel Quartus Prime lite edition.
Shashank V M
  • 2,279
  • 47
Bind syntax: bind dut : dut_inst properties dut_bind (.pa(da), .pb(db));
Place it inside the testbench module after instantiating the DUT.
Since Quartus tool is for synthesis, use a compiler directive to let the synthesis tool skip the assertion.
Example:
module tb();
    logic [7:0] ta;
    logic [7:0] tb;
// if SYNTHESIS is not defined, include below code
`ifndef SYNTHESIS
`endif
// end if
    initial begin
    end
endmodule
Pass SYNTHESIS as a compilation option during synthesis to let the tool skip the assertion.
Shashank V M
  • 2,279
  • 47
  • What is and how do I use the directive you mentioned? – Kyriafinis Vasilis Jul 09 '23 at 10:35
  • @KyriafinisVasilis updated my answer – Shashank V M Jul 09 '23 at 10:40
  • @KyriafinisVasilis since Quartus is for synthesis, don't include testbench in it. Please accept my answer if that helped! – Shashank V M Jul 09 '23 at 10:55
    I surrounded the bind with the `// synthesis translate_off` `// synthesis translate_on` directives and Quartus synthesized the code but now I have problems on modelsim saying `Error: (vsim-3033) Instantiation of 'properties' failed. The design unit was not found.`. I suspect it is because the design was not synthesized – Kyriafinis Vasilis Jul 09 '23 at 11:02
  • Also, I don't use the testbench as the top module and I have it set up in Quartus as a testbench for the dut – Kyriafinis Vasilis Jul 09 '23 at 11:05
  • So you got your Quartus synthesis working. The error from modelsim looks to me a separate question. Please ask it in a separate question. The current question is on Quartus Prime. – Shashank V M Jul 09 '23 at 11:08
