For a personal project I'm trying to make a reproduction of a SNES game (Earthbound) which is 3mb in size. Now the easiest way would be fitting the game in a 4mb 27C322 and multiplex the 16 bit bus to 8 bit (there are even pre-made PCBs that take care of the wiring and multiplexing).
However I'm trying to do it by myself, for fun, and with the components I already have at home. This is the schematic I came up with:
eprom selector circuit
Basically I'm using 2 OR gates to combine the output effects of /OE and (inverted)A21 on the eproms and select the correct chip.
Now, I'm by no means an expert in electronics (as you may also have guessed by how I did the schematic) and unfortunately I don't have an oscilloscope to test it by myself, so my question is: will this circuit commute fast enough?
By "Fast enough" I mean in a time ideally =< 120ns (the fastrom specs of the SNES) and mandatorily =< 140ns (the actual time the SNES expect the signals to be stable). Anything over would be trying my luck hoping the components perform better than what the datasheet reports.
If I do the math (from the datasheets) the eproms are both 100ns, the 74F04 inverter is 3.5ns and the 1N5819 is 10ns (on some datasheets, on others I read =< 500ns?!). IF the forward recovery time is always less than the reverse (correct me on this if I'm wrong) it should work.
My doubts are about the 4.7kohm resistor, again, correct me if I'm wrong, but in this circuit the higher the resistance the slower the transition from 1 to 0 will be, but if the resistance is too low, I'm afraid that the opposite will also be true: transitioning from 0 to 1 will require more time. 4.7kohm is a "good enough" pull-up/down resistor for 5v TTL in most cases, but can it work in this case where there could be many fast commutations from 1 to 0 and from 0 to 1?
toolic
  • 5,637
MastErAldo
  • 121
  • What rise/fall time the components need and does it still fulfill the timing requirements how fast the stable data is needed? It just looks awkward when you use F series TTL chips for super fast speeds and then you let a 4k7 pull-up resistor to pull the voltage slowly down. It migh be worth to change the F04 to eg. an address decoder or some other gate. – Justme Jul 08 '23 at 18:54
  • 100ns the eprom, 3.5ns the inverter and 10ns the diode(trr), so 113.5ns. Original SNES maskroms have a response time of 120ns (at least the fastrom variant that is the one I need), but the SNES actually needs the lines stabilized in 140ns so this is my maximum. Using an OR gate IC will be more appropriate, but I don't have any. The combination of components is ackward because this is what I have right now and, apart from that, I'm curious to know if it is achievable. I have plenty of resistors however, so picking a different value is not a problem if that helps to commute the circuit faster.. – MastErAldo Jul 08 '23 at 19:28
0 Answers0
