I was hoping to get some feedback on a circuit I'm building. The schematic is as follows: enter image description here
Some description: This circuit essentially functions as a constant AC voltage source with current booster capability followed by a subcircuit to measure the current in the load. The input voltage is around 24-100 mV rms with frequency ranging from 4 Hz to 100 kHz. The load, as you can see in the middle, is an AC transmission line. In reality, it is a biophysical sample that works like a distributed AC transmission line, but here I approximate it by a discretized version consisting of a cascade of 4 RC stages.
The current supplied by the current booster stage is limited to around 65 mA (in practice ~80 mA) by the Q3 and Q4 transistors. This is roughly the maximum amount of current I want to send through my load. As you can see, I drive the load with small AC amplitude.
Edit 1: I simulated this part of the circuit alone.enter image description here The load is 10 Ω resistance. enter image description here The voltage of the virtual ground (inverting input -- blue line) is much higher than I like (almost half the driving voltage). What might be an explanation for this? Is there a way to fix this, to make it closer to ground? I suspect the culprit is the high current ~1 mA that the op amp has to sink. If this is the case, how should we bypass the op amp and drain this current after it passes through the feedback loop? If I change to bigger load 1 kΩ, the current is smaller ~10 uA, and the virtual ground is closer to the ground.
Edit 2: I simulated this circuit where the current sensor is current-boosted enter image description here I got time scan of virtual ground: enter image description here Bode plot: enter image description here The virtual ground's amplitude of oscillation is much less compared to the non-boosted current sensor, but it has an offset. I have trouble understanding where that offset comes from and how to fix it.
summeriok
  • 51
  • OP37 is not unity-gain stable. – glen_geek Jul 01 '23 at 01:29
    Have you simulated the various parts of your circuit and in combinations? – Andy aka Jul 01 '23 at 09:19
  • @Andyaka the thing is I’m quite new to ltspice. So I might need more guidance on how to simulate this. Let me simulate the whole circuit or at least the current booster in time and frequency domains for a start. – summeriok Jul 01 '23 at 13:19
    It doesn't just apply to you and your question; you find plenty things wrong with your circuit during simulation that you might have missed. On average, it usually saves about 1.5 PCB iterations per job. The more time you spend simulating, the cheaper it is in the long run and the quicker to market. – Andy aka Jul 01 '23 at 14:57
  • @Andyaka For starters, I have simulated the behavior of OP37 as a unity gain follower with capacitive load. Could you take a look my Edit 1 and tell me whether and how I could see that OP37 is unstable at unity gain from this plot? – summeriok Jul 01 '23 at 19:22
  • How does that recent simulation relate to your original post i.e. how does the output load capacitor relate? Anything can be made stable with a big enough output capacitor as a load. The data sheet explicitly says it should only be used at gains greater than 5 hence, the simulation brings nothing to the table and proves nothing. – Andy aka Jul 01 '23 at 19:28
  • I meant just to understand the principle behind this to think for myself since I am just learning this stuff. In fact, I am a physicist who needs to design this stuff for my experiment. – summeriok Jul 01 '23 at 19:37
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/146982/discussion-between-summeriok-and-andy-aka). – summeriok Jul 01 '23 at 19:53
  • Some things I noticed: (1) direct connection from output to input may be problematic, and some non-zero impedance would be advised. (2) Your 10 uF power supply bypass capacitors should be supplemented with some lower value (~100 nf) for higher frequency stabilization. – PStechPaul Jul 02 '23 at 21:05
    @PStechPaul I agree with adding the ceramic 0.1uF. Actually I always do that, but I just didn't make that explicit in this schematic. I know about adding a small resistor in the feedback loop. I read that using a matching 50 ohms would help minimize the bias current if the source's impedance is 50 ohms. But I tried that out and didn't see an improvement. Maybe the bias current is already quite small. I don't know. – summeriok Jul 02 '23 at 22:40
  • @Andyaka Ok, I cleaned up the post a bit and added a simulation of part of the circuit to edit 1. Can you take a look? – summeriok Jul 02 '23 at 22:41
    What is the actual problem? Can you do a parameter sweep or otherwise demonstrate the undesired behavior? – PStechPaul Jul 02 '23 at 23:05
  • @PStechPaul the problem is I want to make a circuit that can source a fixed AC voltage and can measure the current through this load. (You can read the description in the main post for more details.) In Edit 1 (in the main post), I simulated part of the circuit with a 10 ohms representative load and found the undesired behavior that the inverting input of the second op amp deviates too much from ground. Please see Edit 1 at the end of the post. I want a fixed voltage across load, so I need the other end of the load to be as close to ground as possible, while being able to measure current. – summeriok Jul 02 '23 at 23:17
  • Where is the actual load? Is it in the feedback of U3? Is the capacitor actually 100 pF as shown? – PStechPaul Jul 02 '23 at 23:41
  • @PStechPaul I am talking about the schematic in Edit 1. The load is R1 (10 Ohms), at the inverting input of U2. The cap in the feedback loop of U2 is 100pF. – summeriok Jul 02 '23 at 23:46
I refer to the AD711 datasheet.
This behaviour can be expected from any op-amp with finite bandwidth. In your case, the problem is due to a few things:
  1. High gain (100). The op-amp itself introduces phase shift between input and output. If the output were unloaded, gain-bandwidth product of the AD711 is 4MHz. With gain at 100, this places a pole at \$\frac{4MHz}{100}=40kHz\$, where phase shift is at 45°, but onset of phase shift occurs well below this frequency. As phase shift diverges from zero (or, strictly speaking, 180°, as this is an inverting amplifier), the output changes more and more out of phase with the input, and the usual equalisation of inverting and non-inverting input potentials is less and less perfect.
  2. Heavy output loading. R10, the 1kΩ feedback resistor around U2, is making it hard for the op-amp output to keep up with the input. Unloaded, the AD711 has a gain-bandwidth product of 4MHz, but the datasheet also specifies that at full power output, this can drop to 200kHz. You are getting close to full power with such a load as R10.
  3. I would also hazard a guess that the slightly non-sinusoidal trace of the virtual ground suggests that slew rate is also a factor here. With such a heavy load, I imagine that the slew rate has also dropped significantly from the 20V/μs specification, resulting in those somewhat straight-ish portions of that trace.
I'll redraw the section in question. Of interest to you here is the relationship between the signals \$V_{OUT}\$, \$V_{CURRENT}\$ (blue) and \$V_{VIRTUAL}\$ (orange), in the following bode plots of frequency response to \$V_{OUT}\$:
Gain:
Phase:
The gain plot shows a clear roll-off of 20dB/decade at the breakpoint of 40kHz. I've set a green marker at the 10kHz point, and in the phase plot it's clear that phase shift has already begun at that frequency.
The most important trace here is the orange gain plot for \$V_{VIRTUAL}\$. If it were always true that an op-amp with negative feedback acts to equalise its two inputs, then that would be a flat line, of near-zero gain, right across the spectrum.
Obviously here that isn't the case, and from this graph you see that at 10kHz, the amplitude of \$V_{VIRTUAL}\$ is about 10dB down (one third) of \$V_{OUT}\$!
Update
Using U2 as a transimpedance amplifier to provide a virtual ground, and an output proportional to load current seems like a good idea, but it requires U2 to be able to source and sink all current through he load too. That means you would have to bolster the current capability of U2 with a buffer like the one that you used for U1.
Such an arrangement would permit you to measure current without the need for a sense resistor R1, since all load current flows via R10 anyway, with or without R1. R1 only serves to develop some voltage that should otherwise appear across the load, and introduce an error to the measurement.
To increase bandwidth, and maintain a virtual ground at high frequency, feedback resistor R10 should be similar to the load's impedance. Certainly not more than a factor of four greater, to keep loop bandwidth at 1MHz or above:
simulate this circuit
Update 2
Failure to achieve a virtual ground even at DC is clearly a problem with the op-amp being unable to produce sufficient output potential. It's probably a combination of the op-amp being asked for too much current, and R4 and R7 (10Ω) and R10 (4Ω) reducing loop gain considerably.
Driving 1Ω is difficult! You'll need a much better buffer stage to achieve 100mA through R11. Try this:
It's a "diamond buffer". This particular incarnation should permit you to drive a load of 1Ω with up to 1A or so. Q1 and Q4 (and their periphery) are 20mA current sources, used instead of your resistors R1 and R22 (5kΩ), which are huge problems in your own design, since they starve the transistors of the base current they need. They can't be reduced without overloading the op-amp, so you have to take a different approach.
I should also point out that with supplies of ±15V, all the transistors here are stressed, the power dissipated everywhere is much greater than necessary. If you could reduce the supplies to ±10V (or even further, without compromising the op-amp, of course), this will make a big difference. You'll still need to use power transistors for Q5 and Q6, as they dissipate over 1W.
Update 3
There's another approach which requires only one current buffer stage:
U1 is responsible for maintaining \$V_B = V_{IN}\$, by using negative feedback. It produces whatever potential \$V_A\$ is necessary to achieve that equality, even accounting for \$R_S\$ in its output current path.
All load current current \$I_L\$ must pass via \$R_S\$ anyway, so we have a voltage across \$R_S\$ representing load current. The second op-amp U2 is configured as a unity gain difference amplifier, producing \$V_{CURRENT} = V_A - V_B\$, which is the voltage across \$R_S\$, and therefore a measure of load current.
Simon Fitch
  • 27,759
  • 87
  • Thanks. I just wonder if I can solve this issue with another op amp. How do I make a current sensor of mA range while keeping the current boosting capability of the first stage? Any idea? – summeriok Jul 03 '23 at 10:30
  • The reason that stops me from using shunt resistor is that I usually just solder my circuit with through hole components. I dont do PCB, so 0.01 ohms shunt is problematic. – summeriok Jul 03 '23 at 10:38
  • I can post this as a new question – summeriok Jul 03 '23 at 11:08
  • @summeriok It's not clear what this system is expected to do. By trying to get a virtual 0V on one side of the load, and presenting a low-impedance voltage source on the other, all you achieve is to place a controlled *voltage* across the load. That could be achieved by using a *real* ground instead, and all these concerns go away. Then you can use as many op-amps as needed to measure and amplify current sense voltage with whatever bandwidth you require. – Simon Fitch Jul 03 '23 at 11:48
  • @summeriok With this setup, it seems you are trying to control the voltage across the load, and then measure the resulting current through it. Is that correct? If so, then is your concern that the current sense resistor would have to be small so as to not develop too much voltage that should otherwise appear across the load? – Simon Fitch Jul 03 '23 at 12:05
  • yes I want a control voltage and to measure current through load. Given load is effectively 10 ohms or less, the sense resistor should be 0.01 ohms or at best 0.1 ohms. That needs to be made on PCB not soldered breadboard right? Also, do you know where to buy commercial pcb current sensor conponent to measure 1-20mA range? I was looking at this https://www.deviceplus.com/others/how-to-measure-circuit-current-with-a-shunt-resistor/ but just dont know if this comes premade somewhere – summeriok Jul 03 '23 at 12:35
  • @summeriok Well, the transimpedance amplifier is a good idea, and I see why you want the virtual 0V for that. but it doesn't need a sense resistor, since all current flows via R10 anyway. The output of U2 would be a measure of current with or without R1. However, the amplifier output will therefore have to be able to source and sink all that current too! An unbuffered AD711 won't stand a chance. I'm afraid you'll have to buffer the AD711 as you did the OP37, with a current boost stage. I will address this with an update to my answer. – Simon Fitch Jul 03 '23 at 12:57
  • I will look forward to your update. But I tried to boost this U2 as well on simulation using the same booster for U1, but apparently the bandwidth for this transimpedance dropped. Or strange distortion appeared. I can show the simulation later. – summeriok Jul 03 '23 at 13:09
  • @summeriok Of course the buffer itself will require a bandwidth well over 100kHz, and that might be the bottleneck here. I suggest you perform an AC analysis on just that buffer alone, to see how it performs. – Simon Fitch Jul 03 '23 at 13:40
  • A full bridge audio amplifier would be a good fit. But it's unclear why it's needed. – PStechPaul Jul 03 '23 at 20:26
  • @SimonFitch Plz see my Edit 2. I added the current booster to the sensor stage. The virtual ground oscillates much less (which is great), but it has a terrible offset. – summeriok Jul 03 '23 at 21:17
    @summeriok See my next update. Another option you have is to use MOSFETs, since the signals involved are very low amplitude, and \$V_{GS(TH)}\$ is not so big a problem as it would be for systems where you want the output to get close to the supplies. Using MOSFETs could really cut down your transistor count. – Simon Fitch Jul 04 '23 at 13:12
