I have a problem with choosing most appropriate transistor to control backlight of my LCD display. According to datasheet its \$I_f = 60mA\$, and \$V_f = 3.2V\$. My circuitry is all 3.3V based. I want to supply PWM signal from my STM32 F411CEU6, but it can only supply max of 25mA per GPIO pin. Due to rather large \$V_f\$ there is not a lot of space left for Current limiting resistor, and \$V_{DS}\$ or \$V_{CE}\$. I have found 2SC5585TL NPN BJT (datasheet). According to it, if I were to supply 6mA at Base (\$\frac{I_C}{I_B} = \frac{60mA}{6mA} = 10\$) \$V_{CE}\$ should be around 25mV, which leaves 75mV for current limiting resistor.
Will this work as intended? Are my calculations correct? What is the preferred transistor type here BJT, or MOSFET?
toolic
  • 5,637
  • Do you have any higher voltage available? For example, the 3.3 V might have been derived from a 5 V supply. The backlight probably doesn't need a tightly regulated supply, so the 3.3 V regulator would have an easier life. – Andrew Morton Jun 30 '23 at 14:54
  • @AndrewMorton unfortunately I only have 3.3V power supply available at the moment. What do you mean by „tightly regulated supply”? – Andrzej Komor Jun 30 '23 at 15:33
  • A tightly-regulated supply would not have much voltage ripple. – Andrew Morton Jun 30 '23 at 18:09
0 Answers0
