This my circuit of USB * CP2102, which i am using for PIC(18F6722) controller for USB communication (For Hex loading & USB Port communication). My problem is after hex loading, microcontroller can not start without USB connected to my pc, microcontroller having its own different 3.3V & 5 VDC supply. also CP2102 having the different 3.3V rail. Another problem is when i connect my usb to usb connector on board to PC, PC screen is flick for second. If you found any wrong about circuit, please suggest me.
Asked
Active
Viewed 84 times
Does the program on the microcontroller rely on usb to start up? – Bryan Jun 27 '23 at 04:48
@Bryan, No, its not dependent. – Bhushan Waghe Jun 27 '23 at 04:54
3Is that the correct microcontroller part number? Searches for PIC16F6722 don't show many results and seem to suggest that it should be PIC18F6722. Also, the connections to the micro aren't shown. I suspect that the connections to the micro may have some bearing on any problems and it would possibly be helpful if they are shown. With a separate supply, I wonder if the micro is getting parasitic power from VBUS via the RX/TX. – user85471 Jun 27 '23 at 05:56
