I modified by TP4056 charge module like this Adding power path to TP4056 solar battery charger and limit output voltage to 5.5 V or below. But my charger's output is wind-powered so varies a lot, sometimes less than 5 mA, but constantly at 5 V. The problem is that when the power path circuit detects that 5 V is present, it disconnects the battery. But my load draws 50 mA, so the load can't function correctly.
Is there a good way or IC that enables pass-through charging? Power banks made by "Voltaic" do this but they are expensive. I don't know how to reproduce their functionality.
Davide Andrea
  • 16,164
  • 62
Place a power resistor across the wind generator to drag down the voltage to below 5 V when the wind is slow.
Davide Andrea
  • 16,164
  • 62
  • I want to be able to charge even when input current is below 50mA. This also won't work because load current has peaks. – UnknownDagger Jun 25 '23 at 22:19
