I need to control an LED (SSR) at a someway-long distance of about 20 meters (60 feet) from a microcontroller.
A simple LED on/off control type where I could keep it on for a long period of time. The cable is running inside the walls in a house.
I don't have a good experience with such things and have little knowledge on how to make it properly protected from ESD, noise and other things.
Generally, I have the following idea:
- Run CAT5/CAT6 cable and use a pair out of it.
- Put LVDS driver and receiver on tx/rx sides. The LVDS is expected to be TIA-644 compliant (100 Ohms impedance due to CAT5/CAT6)
- I was thinking to use parts like SN65LVDS179, SN65LVDS050 or similar. Maybe some other differential solution with 100 Ohms impedance.
Is that a right approach or am I over-engineering things or maybe missing some other important key points?
Some background: It's actually a thermostat in the living room controlling an SSR on mains located in the basement. I don't have a space to install a relay behind the thermostat so it needs to be located in the basement where it's properly mounted on DIN rail with a proper heatsink.
