I'm making a power-supply circuit for some MCUs using a battery charging-discharging protect module MH-CD42 (both input and output is 5 V).
The module's datasheet says it has a 0.3 seconds switch time when connecting or disconnecting the DC power input, so I use a 10 F super capacitor to make sure those MCUs don't power off due to power loss. But when I power the circuit, it triggers the module's overcurrent protection (2.1 A).
I have tried to add a resistor between the module and the capacitor, but it still doesn't work.
Here are my circuits, with and without resistor.
Without resistor
With resistor
What should I add or how can I change my circuit to solve the problem?
    Without knowing which exact module you are using, answers would be speculative at best. Please update the question with the exact module you are using. – Adam Lawrence Jun 22 '23 at 12:03
  • @AdamLawrence Question updated.The module is called MH-CD42 – Object Unknown Jun 23 '23 at 06:08
  • How much voltage drop do you accept on the load side? – Jens Jun 23 '23 at 21:24
  • @Jens The loads are one ESP8266 Module and one Arduino Mega 2560 Rev3. I think 4.2 V is enough, so maybe less than 0.8 V, or I can add a DC to DC boost module to solve the votage drop. – Object Unknown Jun 24 '23 at 12:09
  • If you can accept 0.8 V drop, you may charge the capacitor via 50-100 ohm and connect a Schottky diode parallel to the charge resistor in discharge direction. This way the capacitor charging current is much lower. During takeover the capacitor feeds the load via diode. A boost converter allows a smaller capacitor. – Jens Jun 26 '23 at 00:32
  • @Jens Do you mean change my circuit to this one [Citcuit 1](https://github.com/UnknownObject000/TemporyPictures/blob/main/circuit-01.png) or this one [Circuit 2](https://github.com/UnknownObject000/TemporyPictures/blob/main/circuit-02.png)? – Object Unknown Jun 26 '23 at 06:34
  • I meant Circuit 2 – Jens Jun 26 '23 at 15:54
0 Answers0
