I live off-grid and want my fridge switch off automatically during the night. The strategy combines a twilight switch and a switch relay.
I'm stuck with the wiring of the switch relay (I am not an electrician).
Spec: https://www.phoenixcontact.com/en-pc/products/relay-module-rif-1-rpt-lv-230ac-2x21-2903331
Would you please advise:-
- Which ports are for the power input?
- Which ports are for the control input?
- Can the control input voltage be 230V?
- Which ports are for the reversed output?
- What are the other outputs for?
The inverter has two operation modes:
- continuous
- on-if-need
The on-if-need mode switches on in every minute to check if there's any need. Ideally I'd use the on-if-need mode to minimize battery usage during the night (there is no timer on the inverter). I don't know if there's any effect on the relay's designed operation if neither power nor control voltages are applied then it receives either power only or both voltages.
Many thanks
