Note: This mini-tutorial is based off of the official information here on the Arduino site. It also involves using the official Arduino IDE.
Note 2: The links provided to products may be either Farnell links (as they contain data sheets) or the actual product pages on the manufacturer's website.
Step 1: Get an external programmer
The first thing to note is that you need an external programmer to avoid the bootloader and reclaim the 1K or 2K of memory which it takes up (12.5% of the total memory). You could use an AVR-ISP, a STK-500, or a parallel-port programmer - the official Arduino site has instructions for this here. Note that you can't communicate with the board through the parallel programmer - the advice is to use a serial cable for that. The main benefit of using a parallel programmer is that they're much cheaper than the others if you're willing to do some soldering - you only need a few (3) resistors and a few connectors, whereas an ISP can set you back up to £30/$50 (conversion rate is approximate).
Step 2: Edit the Arduino preferences file
Next you'll need to configure the Arduino IDE to allow you to circumvent the bootloader. Make sure you do NOT have the Arduino IDE open! The preferences file preferences.txt
can be found at the following locations, depending on your operating system:
C:\Documents and Settings\<Username>\Application Data\Arduino\preferences.txt
(Windows)
/Users/<Username>/Library/Arduino/preferences.txt
(Mac)
~/.arduino/preferences.txt
(Linux)
To get to the preferences file in Windows, go to the start menu and then go to %appdata%
(NB: I don't use Windows regularly, feel free to correct me). Then navigate to Arduino and then to preferences.txt
On Mac, either use Terminal, and do:
cd ~/Library/Arduino
open .
Or in Finder use Goto (Cmd-Shift-G) and enter ~/Library/Arduino
. These both take you to a Finder window with preferences.txt
in.
On Unix systems, folders starting with a '.' (such as .cache
, .git
) are by default hidden, so in Linux you'll need to use the Terminal and enter:
cd ~/.arduino
nautilus .
Note: You can replace nautilus with gnome-open
if you wish. I know that these both work on the common flavours of Linux, but you may have issues on some of the more 'exotic' flavours.
Once you have found the preferences.txt
file, open it and change the upload.using
from bootloader
to the name of one of the programmers in the ./hardware/programmers.txt
subdirectory. If you only want to remove the bootloader from one board, in ./hardware/boards.txt
you can change the <board>.upload.using
parameter and all of the other boards will still use the bootloader. Then just save the relevant file and close it down (my Arduino just crashed and I almost lost the answer, possibly because I forgot to do this).
Step 3: Upload the sketch
Once you've edited the relevant file, open up the Arduino IDE again and upload the sketch as normal. If you just edited ./hardware/boards.txt
, then only that particular board will not have the bootloader, but if you edited preferences.txt
then all of the boards won't have the bootloader.
Step 4: Replace the bootloader
If you want to have the bootloader on your boards again (for whatever reason), then first remove either the <board>.upload.using
parameter or set upload.using
back to bootloader
. Then you'll need to burn the bootloader back on to the affected boards - this answer explains reasonably well one method of doing it, and there's an easier method to upload the Arduino bootloader only with just an ISP (which you should have from earlier) on the official site here.
