I am trying to set up a similar circuit in LTspice and making necessary modifications to change it to a bandpass filter. I have a couple of questions regarding this model and was hoping someone could help me with it:
Where do I call the "skin effect" and "radiation" resistance from the library? it appears to be non-existent
How is the magnetic field being set up as a parameter based voltage source? Basically I am stuck at defining the voltage equation for the loop
How to make certain components frequency dependent? I guess by using the command Laplace but I have never used it before in form of an equation
