I'm using a sensor that has ethernet output. This new sensor is a replacement of yet another same sensor that seemed to have short-circuit like situation between its RX+/- pins.
After connecting the new sensor to my single board computer (SBC) there was no sign of activity/data and I checked the voltage on various pins and observed that the TX+/- pins appear to be having 0.8 Ohm resistance.
enter image description here ( source)
The circuit schematic of a magjack ethernet connector shows internal magnetic couplings and they might make the circuit appear like a short-circuit but be functionally normal. I'm confused if the RJ45 communication interface is intact or otherwise.
My question is: what is the expected resistance between TX+/- pins (and RX+/-) pins in a functional RJ45 socket?
vyi
  • 761
Most Ethernet transformers seem to be 0.9 ohms max so your 0.8 ohms is within specs.
The trasformer coil is basically a short circuit if you try to measure it with a multimeter.
Justme
  • 127,425
  • 261
