RE: Circuit protection for small health & beauty product (for mass-production) similar to a foot spa whereby a portion of the user's body will come into direct contact with 1.5 gallons of water within the vessel. See original question link here: Do I still need a fuse if I'm using a GFCI?
Main components of vessel:
IP65 silicone heat pad: 500 watts @ 120VAC = 4.17a Note: adhered to stainless steel bottom; does not come into contact with the water. Air pump: 17 watts @ 12VDC = 1.42a LED: 70 pixels @ 0.3w per pixel/5vdc = 4.2a Total: 9.79A + 1 amp (auxiliary parts) = 10.79a total
Main components of PCBA: OLED display, two Pots, power button and AC/DC converters
Safety measures implemented to-date:
  1. Silicone heat pad in lieu of heating element
  2. 14/3 or 16/3 (TBD) GFCI cord similar to this one: https://www.amazon.com/dp/B000HEKUJA Note: Power cords with GFCI do not come with overcurrent protection. We will require overcurrent protection for the following reasons: A. we will seek UL, CE and other certifications in the future; B. "The Penny in the Fuse Box" https://www.schererelectric.com/blog/electrical/the-penny-in-the-fuse-box-and-other-diy-electrical-panel-nightmares/ Note: One of our stakeholders owns a large mechanical contractor company. He was the first one to alert me to "The penny in the fuse box" scenario. He says, "it happens more than you would believe. So, YES, you need overcurrent protection!"
Our options as we see them:
  1. GFCI cord + auto reset thermal circuit breaker like these: https://www.kuo-yuh.com/97-series-auto-reset-circuit-breaker.html https://www.alibaba.com/product-detail/Kuoyuh-97-series-10A-single-pole_1600651596086.html
Notes: This would have been the ideal solution for us had it not been for the potential major negatives as pointed out by these two EE's: see @PStechPaul comments on my previous question Stack Exchange link above. Also, see LEX@REDARC #1331 comment (second from top) here: https://www.redarc.com.au/forum/discussion/255/circuit-breaker-vs-fuse
Question: Is this still a problem with "thermal" auto reset circuit breakers today? One would think they have perfected this technology by now.
  1. GFCI cord + PCB (on-board) fuse: this still may be an option, although we still have reservations about this. Our initial concern was if the fuse blows, they will need to take it for repair. However, our PCB designer said: "if a major fault occurs they will need to take it to the repair shop anyway." Note: (added 6/12/23) a few engineers brought up that in some cases, overloads are temporary for one reason or another and that all it takes is a flip of the circuit breaker to be back up and running again. A PCB fuse cannot be replaced by a layman. Hence, should a temporary overload blow the fuse, the user would be required to take it to the shop for no other reason but to replace the PCB fuse if the problem for the temporary overload could not be determined.
  2. GFCI cord + manual reset circuit breaker (off-board). This seems to be LEX@REDARC preferred option although his comments were made nine years ago before advancements in auto reset fuses occurred, assuming advancements in auto reset fuse technology have occurred and I don't know that they have.
  3. Have someone make a custom GFCI cord with overcurrent protection. Note: if you are interested PM me. We will be needing 5,000 (+/-) per month starting Q3, 2024.
Our conclusions to-date based on what we've learned to-date:
  1. if auto reset fuses no longer exhibit the potential problems as noted by @PStechPaul and LEX@REDARC above, then we would probably choose this option. If the potential problems with auto reset fuses still exist, we will most likely rule this option out; even if there is a work-around because we prefer following the KISS method.
  2. still a possibility, but have reservations
  3. still a possibility, highest probability Note: the question with this option now becomes...do we use a GFCI circuit breaker in a distribution box or use #4 with a push button circuit breaker mounted separately in the product's compartment.
  4. still a possibility, but have reservations
Your comments and suggestions will be very much appreciated.
Thank you in advance,
Notes: That link to the cord is for example purposes only. We won't be buying any parts for this mass production product off of Amazon. We are an OEM and will be dealing in volumes where we will be able to bypass all distributors and only deal with the manufacturers of any parts we utilize. We will be required to get three bids and probably accept the middle bid, which is typical.
We've already considered fuse inlets for the main power cord. The product has another inlet with a conventional shape on the vessel (the vessel and power tower are not integral; the tower plugs into the vessel) so we had to change the main power cord and inlet thereof to an unconventional shape to force the user to use our GFCI cord which will be supplied with the product and also to prevent the user from plugging the main power cord into the inlet on the vessel. Because of the unconventional shape of the main power inlet, we have been unable to find a fuse/inlet combo so we have ruled using a inlet/fuse combo out for the time being.
The GFCI cord can not be attached to the power tower because of packaging related problems and assembly related costs. Also, there are two types of GFCI cords 120vac or 230vac; one for EU/UK and the other for US. Hence, less cost to just change the cord out in lieu of attaching two different cords 120vac or 230vac to the tower. Also, if GFCI goes out, the user just buys an other GFCI power cord from us.
tayglo
  • 73
For safety measure #2, the GFCI cord is basically an extension cord which will also need to have the device's power cord plugged into it. I think it would be too easy for the customer to bypass, and it is also very expensive ($37!). The ideal location for the GFCI module is at the outlet, but I think the power cord should be permanently attached. Perhaps it would be good to have the GFCI device as a part of this cable, as it is on my pressure washer.
GFCI adapter
Image from Amazon
It may be more convenient to have a GFCI with a short pigtail to a standard plug, and then add a cord with a female IEC connector that would be inserted in a male inlet on the device. You can get power inlets with built-in fuses for about $2.
Power inlet
You could add a deliberate 6 mA ground fault by connecting a 5k resistor from hot line to GND and make it so the user must clear the fault before allowing the device to power up.
(edit) It might be something like this, where the 5k resistor causes the GFCI to trip. The user would press the button, which disconnects the fault and latches the relay ON. The GFCI will still trip if a real ground fault occurs. I need to make another edit.
PStechPaul
  • 7,195
    Thank you for your continued interest in helping out. I've addressed your suggestions in the main body of my question and explained why the things you're recommending are not possible for our circumstance. You may or may not want to delete this answer, I'll leave that up to you. Thanks again. – tayglo Jun 11 '23 at 03:05
  • I think I'll keep it open for now. Some of the information might be useful to others. And there may be further discussion of protection for the PC board. I also looked for DIY GFCI circuits, but I didn't find any - there are probably a lot of liability issues. – PStechPaul Jun 11 '23 at 03:41
  • We are hopeful when we reach out to the GFCI manufacturers they will be willing to make a GFCI with overcurrent circuit breaker for cord installation which will probably be our best bet when all is said and done. It's unbelievable that in the 21st Century there doesn't seem to be any on the market. Or, maybe there is and we just haven't found one yet. – tayglo Jun 11 '23 at 03:51
  • @tayglo In the majority of the world (at least as far as I'm aware), GFCIs are installed routinely on all residential circuits, so they can just be assumed to be present. No need to put an extra one on a cord when it would make the cord cost $20 or $30 instead of $5 or $10. – Hearth Jun 14 '23 at 05:29
  • I asked an EE friend to look at this entire chat (both questions) and give me his thoughts. He said the most likely reason I'm not getting more responses on my two questions is because @manassehkatz-Moving 2 Codidact already answered my question. So I went back and read his answer again on question #1 and sure enough he not only says to put the GFCI at the end of the power cord but gives the reason why it needs it "because some outlets don't have GFCI protection and are grandfathered in": manassehkatz-Moving 2 Codidact . Does that change your mind? If so, I can do that and focus on the fuse. – tayglo Jun 14 '23 at 12:24
  • @hearth If he is correct, and it now it makes sense that he probably is, then I need to forget the GFCI circuit breaker within the spa's compartment and focus on potential liability risks in using a GFCI power cord. The only risk I can think of is...if someone changes the cord out for a conventional cord thereby bypassing our GFCI would potentially increase our liability. That would leave me with two options: 1. attach the cord to the spa or use a non-conventional power inlet on the spa and a corresponding non-conventional connector at the end of the cord which forces the user to use our cord. – tayglo Jun 14 '23 at 12:44
  • @Hearth But I see your point; foot spas don't typically come with a GFCI cord so it appears they agree with you that such GFCI protection is already present in the house. However, there are several shock deaths annually related to foot spas which seems to validate the answer with the most up votes on my first question. – tayglo Jun 14 '23 at 12:52
  • @tayglo Right, I'm not saying your idea of using a GFCI is a bad one! I'm just explaining why cord-mounted GFCIs are uncommon. – Hearth Jun 14 '23 at 13:49
  • You could have a GFCI test button on the spa to put a 6 mA or so load (about 5k) from hot to GND, It could be set up so that the user must press the button to disconnect the test load with a latching relay. – PStechPaul Jun 14 '23 at 16:57
  • @PStechPaul can you be more specific as I'm not an Elec. Eng.? Thanks – tayglo Jun 14 '23 at 20:09
Looks like I may have found the answer:
I found a 2 Pole 16A GFCI: https://www.sourceasi.com/product/ndb1l-32c-16-120v-16-amp-gfci-circuit-breaker/
It's DIN rail mounted which is also standard in EU/UK as I understand it. I can cut an access hole in the aluminum control tower sidewall. Then, I can mount a distribution 2 Pole switch DIN rail protection box, like the one in the link below, via the box face plate to the the inside of the control compartment tower and forget the idea of a GFCI power cord and fuse. Then, for product shipped to EU/UK we can just change out the breaker to the 240vac version. Also, in case the the GFCI breaker goes out, we can just sell our customers a replacement breaker instead of a replacement GFCI cord.
If I'm understanding all this correctly by now, we can also eliminate the on-board fuse option as well.
https://www.amazon.com/gp/product/B09P7Z2C77/ Note: For example purposes only. They may make a face plate mount box. If not, we can use this type of box and use the two screw holes in front to mount it via screws through the aluminum tower sidewall.
This idea is still in it's infancy but on the surface it sounds logical enough to warrant further investigation and to present to my team on Monday.
Also, in regards to the prices shown here, I consider those good prices for the retail market. Therefore, I'm very encourage I can get much lower pricing on a mass-production scale.
Also, since the power/control tower compartment is made with aluminum extrusion, I can design extruded snap lock fins on the interior whereby the distribution box can just snap into place thereby making assembly process that much easier.
If any of you have any additional thoughts on this path, it would be much appreciated.
Edited 6/13/2023 to include my further thinking on the GFCI circuit breaker mounted in a distribution box within the spa's compartment:
The potential problem with this is...I think that the power cord from the wall outlet to the portable spa will not be protected. Hence, what happens if the user reaches over and grabs the cord while they're using the spa.
tayglo
  • 73
    My main concern with that GFCI breaker is that it trips at 30 mA, which I think is too high. Most residential GFCI outlets have a trip point of about 6-10 mA. The threshold of perception is around 5-15 mA, and 30 mA is rather painful, although usually not dangerous. I'm sure you can have a device like this manufactured with whatever threshold you require, and there are probably specifications for this. – PStechPaul Jun 11 '23 at 07:54
  • @PStechPaul Good observation, I missed that. 30mA is ground fault for equipment, I need ground fault for people which is 4-6mA I think. I'll research some more this coming week to see if I can find a residential 15A GFCI breaker. If not, I'll contact the manufacturer of this brand and ask them if they make such a GFCI breaker. Like you said, I don't think it will be a problem, or at least I hope not. Thanks for the head's up. – tayglo Jun 11 '23 at 08:14
  • After doing a little more research, it looks like the operating threshold is an easy adjustment if it's made for the North American market because we use electronic technology which is easy to operate at the 6mA level whereas the standard for Europe and the rest of the world is 30mA because they use electromechanical technology which is "extremely difficult" to operate at 6mA. So as long as I find a company that manufactures for the North American market, I should be good to go. – tayglo Jun 11 '23 at 08:54
  • Also, it's worth mentioning, that once I complete the general design, we will have one of the automation companies confirm and/or improve on my design to make sure it meets or exceeds UL standards before we go to market; such as this company: www.westernautomation.com – tayglo Jun 11 '23 at 08:58
