What can I add to my air compressor so it automatically turns off when it exceeds a certain pressure, and on when below a certain pressure? Is there a device that I can manually set lower and upper pressures limits that acts as an on off switch?
The compressor does not have a receiver tank - it pumps into a 10 metre hose with a regulator at the end.
Cheers!
  • In effect your 10m hose will act as the receiver tank, and with such a tiny "tank" your compressor is going to run like brrrp-brrrp-brrrp as the pressure switch cycles on & off while you're using the air. Any normal compressor pressure switch is going to have its lifetime drastically reduced by being used in such a fashion. – brhans Jun 06 '23 at 13:14
  • thanks for your replies @brhans and @Solar Mike! I am working out how [this company](https://www.youtube.com/watch?v=KqEHeKudoaY) `code` have their compressor setup... note how it cycles on and off as the diver breathes. From what you've said - a receiver tank would be a worthwhile addition to the setup. – WindowHelmet Jun 06 '23 at 13:23
A pressure switch, actually used on compressors to do exactly what you describe, but without a receiver it will cycle very rapidly.
Solar Mike
  • 6,319
  • They make pressure switches for air compressors with built in hysteresis but as @brhans said, with a 10 gal tank the hysteresis isn't doing much. – vir Jun 06 '23 at 17:01
