I would like to construct an electronic virtual 3-phase motor for testing VSD/servo drive systems in the workshop, where the actual motor is not available for testing (e.g. because it is on a running machine, or it hasn't arrived yet, etc).
Let's assume it's a squirrel-cage induction motor with fixed ratings (1hp) for now. Of course, it would be easier to obtain such a motor and just wire it to the drive, but where I'm heading is a set of electronically configurable motors for testing many different systems.
- Can I do this by connecting appropriately sized inductors and resistors between the drive and a 3phase inverter? I.e. would this be able to produce an accurate model of such a motor, assuming smart enough control of the inverter? There would be voltage test points so that the inverter controller can model the motor accurately. See below:
If simulated encoder feedback is added, can this architecture also be used to model permanent magnet 3phase servomotors? If no, what would need to be modified? If yes, would the inverter controller need to produce complex (non-sinusoidal) waveforms?
To make an electronically configurable motor, can I switch different inductances and resistances in and out using contactors / relays?
