I want to use this Step Up Converter (Boost Module), (https://www.amazon.com/gp/product/B0B7JGJ67J/), to power a 12V .15A blower fan using a 3.7V 2500 mAh battery. The step converter says that it is for a 3.7V supply but in the description, it says that the input is from 4.5V to 8V (which is higher than the 3.7V of the battery). What is happening here?
Justin E
    Welcome! Input would be for the charger side of things, which is made for 5 V USB. – winny Jun 01 '23 at 13:10
  • That makes perfect and obvious sense. Thank you. – Justin E Jun 01 '23 at 13:13
    Beware: https://electronics.stackexchange.com/a/429561/1743 Unless you can get a proper schematic and verify that the charge current measurement isn't being affected by load currents, you should not use that module. – Ben Voigt Jun 01 '23 at 13:34
    Because: you are buying electronics from bad sources like Amazon, whom have no quality concerns whatsoever. Buy from serious electronics vendors instead: Digikey/Mouser/RS/Farnell etc etc. – Lundin Jun 01 '23 at 14:14
0 Answers0
