I am trying to write a testbench for a basic component, but I am getting an error saying:
bad default binding for component instance (component port not on entity)
I have tried recompiling multiple times in both quartus and questa, have restarted both programs, and nothing seems to work. I have attached the code for the component and its testbench, and an image of the error message in questa. Any help is greatly appreciated.
Component:
library IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity H1_dataflow is
Port(
F3 : out std_logic;
F2 : out std_logic;
F1 : out std_logic;
F0 : out std_logic;
A : in std_logic;
B : in std_logic;
C : in std_logic;
D : in std_logic
end H1_dataflow;
architecture dataflow of H1_dataflow is
begin
F3 <= (NOT(A) AND (NOT(B) OR NOT(D))) OR (NOT(B) AND C);
F2 <= (NOT(A) AND B AND NOT(D)) OR (B AND NOT(C) AND D) OR (A AND C AND D) OR (A AND NOT(B) AND NOT(D));
F1 <= (NOT(A) AND D) OR (A AND C AND NOT(D)) OR (A AND NOT(B) AND NOT(D)) OR (A AND NOT(B) AND C);
F0 <= (NOT(A) AND NOT(C) AND NOT(D)) OR (A AND B AND C) OR (A AND C AND NOT(D)) OR (A AND NOT(B) AND NOT(C)) OR (NOT(A) AND NOT(B) AND C AND D);
end dataflow;
Testbench:
library IEEE;
use std.textio.all;
use ieee.std_logic_textio.all;
end H1_dataflow;
architecture test of H1_dataflow is
component H1_dataflow
Port(
F3 : out std_logic;
F2 : out std_logic;
F1 : out std_logic;
F0 : out std_logic;
A : in std_logic;
B : in std_logic;
C : in std_logic;
D : in std_logic
end component;
signal inputs : std_logic_vector(3 downto 0);
signal test_output : std_logic_vector(3 downto 0);
signal exp_output : std_logic_vector(3 downto 0);
begin
dev_to_test: H1_dataflow
port map(
F3 => test_output(3), F2 => test_output(2), F1 => test_output(1), F0 => test_output(0),
A => inputs(3), B => inputs(2), C => inputs(1), D => inputs(0)
expected_proc : process(inputs)
begin
case inputs is
when "0000" =>
exp_output <= "1001";
when "0001" =>
exp_output <= "1010";
when "0010" =>
exp_output <= "1000";
when "0011" =>
exp_output <= "1011";
when "0100" =>
exp_output <= "1101";
when "0101" =>
exp_output <= "0110";
when "0110" =>
exp_output <= "1100";
when "0111" =>
exp_output <= "0010";
when "1000" =>
exp_output <= "0111";
when "1001" =>
exp_output <= "0001";
when "1010" =>
exp_output <= "1111";
when "1011" =>
exp_output <= "1110";
when "1100" =>
exp_output <= "0000";
when "1101" =>
exp_output <= "0100";
when "1110" =>
exp_output <= "0011";
when "1111" =>
exp_output <= "0101";
when others =>
exp_output <= (others => 'X');
end case;
end process expected_proc;
stimulus : process
variable ErrCnt : integer := 0;
begin
for i in 0 to 15 loop
inputs <= std_logic_vector(to_unsigned(i,inputs'length));
wait for 10 ns;
if(exp_output /= test_output) then
ErrCnt := ErrCnt + 1;
end if;
end loop;
if(ErrCnt = 0) then
report "SUCCESS! Full Adder test completed.";
else
report "The Full Adder is broken." severity error;
end if;
end process stimulus;
end test;
