I am using the AO3415 to do high-side switching.
My aim is to reduce power consumption as this low-power device should run for ages on a single battery. System quiescent current is less than 5 μA. (VCC is 5 V)
What is the smallest pull-down resistor value I can use to reduce power consumption but not cause problems?
This P-channel MOSFET is switched a maximum of once every second.
I have checked How do I calculate the required value for a pull-up resistor? and Calculating the pulldown resistance for a given MOSFET's gate among others but am not given a concrete value or formula.
[![enter image description here][1]][1]
A 100 kΩ resistor causes 50 μA of loss when the gate is driven high, which is far too much, especially compared to the rest of the system. The gate is high half the time.
How low can I go? 100 kΩ? 470 kΩ? 1 MΩ? 4.7 MΩ? Even lower?
