FPGAs have among the largest packages and the most voltage rails. This is especially true of the high end devices e.g Stratix, Virtex Ultrascale+ e.t.c. This means a whole lot of decoupling capacitors. Decoupling capacitors is one way to improve the power delivery network and this is very important. Problems with power integrity can actually manifest as problems with signal integrity due to ground bounce.
How does a person know how much decoupling capacitors to use for an FPGA design and their values? Is this an exact science science that must be acquired like with the knowledge of signal integrity, or does it rely only on datasheet and/or outputs from the FPGA design tool (Quartus, Vivado, Libero e.t.c)?
quantum231
  • 11,218
  • 99
  • 192
    Usually the vendor tells you. – user1850479 May 29 '23 at 19:16
  • If we know what values to use and how many of them to use, what is difficult in designing the PDN? I mean that is all there is to it right? Also, do you they give value and quantity or also some other attribute like ESR, material (ceramic, tantalum e.t.c.)? – quantum231 May 29 '23 at 19:35
  • Although its not directly related to the subject, the number voltage rails on the bigger FPGAs are just terrifying. – quantum231 May 29 '23 at 21:09
  • The dat sheet will usually have specific recommendations. There may also be a reference design from the vendor that gives an actual example. – Kevin White May 29 '23 at 22:18
It's not an exact science - usually you get an estimate how your design will consume energy in an FPGA and some margin is added and that's what you need to provide.
Later you ask what's the difficulty.
The FPGA will consume current at the operating frequency, which is high, and the difficult thing is to provide enough capacitance so that the voltage does not have too much ripple when the FPGA gulps current.
The problem is, neither the capacitors or the PCB are ideal. The PCB wiring will have resistance and inductance. Resistance will limit how much instantaneous current is available, and inductance will limit how quickly you can get it. Capacitors themselves have internal ESR and ESL. And depending on dielectric type, a 100nF capacitor may have much less than 100nF of capacitance under the DC voltage bias.
So the difficulty is that you need to provide a power delivery network with low enough impedance at the range of required frequencies. That takes multiple capacitors with multiple capacitances and package sizes to have an effective PDN with low enough impedance at wide frequency range.
Small size and capacitance low-ESL caps near power pins for highest frequencies, slightly larger size with slightly larger capacitance further away for slightly lower frequencies, and the most largest size with largest capacitance the furthest away for the lowest frequencies.
Justme
  • 127,425
  • 261
  • What problems does ESL and ESR create? I guess both of them depend on the package size of the capacitor but am not sure about other details. – quantum231 May 29 '23 at 20:34
  • Like I said, ESR causes voltage drop so it limits maximum current, and ESL causes voltage drop because it limits low long it takes before requested current is available. – Justme May 29 '23 at 20:36
  • oh, I thought you were talking about the PCB tracks there. – quantum231 May 29 '23 at 21:02
    so if we have put in these decoupling capacitors according to vendor datasheet, do we still need to run some sort of simulation to ensure that the power integrity is preserved? – quantum231 May 29 '23 at 21:03
    @quantum231 You shouldn't need to if your layout is reasonable. But if you are costing cutting you would run the board through a simulation to see exactly how few capacitors you can get away with. – DKNguyen May 29 '23 at 21:39
  • Alright, there is one capacitor that has been omitted from discussion, these are the power supply and ground planes. The capacitor formed by these is going to be small in capacitance but will have low ESL (not sure about ESR). Does this capacitor ever matter? – quantum231 May 29 '23 at 21:50
    @quantum231 typically not, because directly below the FPGA both planes will be as holey as Swiss cheese - there's signals to be brought out. – Marcus Müller May 29 '23 at 23:20
  • I see, when exactly could this plane capacitance be relevant? I keep seeing its picture in some presentations related to PDN and PI – gyuunyuu May 30 '23 at 09:52
