So I have multiple wires (~5) from 0.75mm² to 10mm². I want to connect them like with Wago, but they are bigger than Wago can hold, and I need to fix them in place on panel.
Example. So these have holes to screw them on panel. This is exactly what I need.
But these things are expensive (~40$ per two blocks). What else could I use?
Ri Di
  • 753
  • What do you mean by "like with Wago"? Would a screw-down terminal block suffice, or do you specifically want the lever action Wago connectors have? – Hearth May 26 '23 at 05:15
  • Also, can you terminate the wires with connectors, or do they have to remain bare (or perhaps enferruled) wires? – Hearth May 26 '23 at 05:29
  • I would prefer screw wire terminals for better reliability, so no bare wires. It is for shaky/vibrating environment. – Ri Di May 26 '23 at 06:01
0 Answers0
