I'm working on a project that requires me to amplify 70 pA to read out at 10 V (the digitizer I'm using to collect data has a range of 0 to 10 V readout). On top of this, I need to sample my voltage at either 2.5 MHz or 5 MHz. I'm greatly limited by the GBW of op amps since I can't get a reasonable gain at the frequency that I require without multiple stages. I am considering 5+ stage amplification but a friend of mine who studies EE said he thinks the noise generated from the additional connections would greatly impact the precision of my circuit. I've attached an example circuit by TI that I'm basing my design off of, in this example, they claim only a GBW of >9.5 MHz is required to achieve 53.6K gain (94.58 db) at 1 MHz, which doesn't make sense by my understanding of how GBW works (GBW = gain * frequency).
Why is only 9.5 MHz of GBW is required in this case? I would think that 94.58 MHz of GBW would be needed to achieve the given gain at the given frequency.
Will using 5+ stages of op amps be an issue? I don't have much experience working with circuits so I'm not sure what the standard method is.
