I was reading about the quality factor of a series RLC circuit. The quality factor is defined as
$$2\pi*\frac{\text{maximum energy stored}}{\text{total energy lost per period}}$$
Here maximum energy stored is calculated at the resonant frequency. My doubt is, is there any other frequency at which the maximum energy stored in the circuit is greater than that at resonance?
I have done the following calculations.
Energy in storage at any instant, $$ \mathrm{Energy}(t)=\frac{1}{2}*\textrm{L}i_{L}^2(t)+\frac{1}{2}*\textrm{C}v_{C}^2(t)$$
$$\text{Let source voltage}=v_{m}sin\omega t$$
After some calculations
Energy in storage at any instant = $$\frac{1}{2}*\frac{v_{m}^{2}}{[R^{2}+(\omega L-\frac{1}{\omega C})^2]}*[L*sin^2(\omega t-tan^{-1}\phi )+\frac{1}{\omega ^{2}C}*cos^2(\omega t-tan^{-1}\phi )]$$
At resonance, this reduces to a constant value, $$ \mathrm{Energy}(t)=\frac{1}{2}*\frac{v_{m}^2*L}{R^2}$$
This is the maximum energy stored at resonance.The question is, is there any other radian frequency at which the function ' Energy(t) ' peaks greater than that at resonance?
Voltages across R, L, C & I versus frequency
Image source: Boylestad, Robert L. Introductory Circuit Analysis. Pearson Education.
SamGibson
  • 17,231
  • 58
Lelouch Yagami
  • 397
  • In case the chat room is inaccessible now that I deleted my answer, it's now clear that the maximum peak voltage across the capacitor does indeed peak at slightly below true LC resonance. I found this through simulation. Sorry for my misguided answer. – Andy aka May 21 '23 at 18:23
  • @Andyaka . It's ok. – Lelouch Yagami May 21 '23 at 18:31
I was wrong in my "now deleted" answer and, I should have been less hasty in posting it. For a simple RLC series circuit you can look at the voltage across the capacitor just as you would when designing a simple 2nd order low-pass filter like this: -
If my brain had worked immediately, I'd have posted this picture from my basic website: -
  • The maximum peak amplitude is: \$\dfrac{1}{2\zeta\sqrt{1-\zeta^2}}\$
  • This occurs at a frequency of: \$\omega_n\sqrt{1-2\zeta^2}\$
There is a proof further down that linked page. For the peak inductor energy, this occurs at true resonance (\$\omega_n\$) because the reactances cancel and, current becomes a maximum.
  • This is my conclusion: For a particular frequency source, maximum energy is stored in the circuit at the moment when capacitor voltage peaks and inductor current is zero (except at resonance frequency where energy stored at any moment is constant). Capacitor voltage peak is maximum for frequency $$\omega_n\sqrt{1-2\zeta^2}$$ as shown in the frequency response above. Therefore, maximum energy storage occurs at $$\omega_n\sqrt{1-2\zeta^2}$$. Is this correct? – Lelouch Yagami May 24 '23 at 13:13
  • @LelouchYagami that's what my answer says; maximum capacitor voltage occurs at that frequency (slightly lower than resonance). – Andy aka May 24 '23 at 13:31
  • If we consider the dual of this circuit, i.e., parallel RLC circuit, does the current through the inductor determine at what frequency maximum energy storage occurs? – Lelouch Yagami May 24 '23 at 14:22
  • Maybe ask that as a brand new question @LelouchYagami <-- without going into the math I believe it's simpler i.e. peak voltage coincides exactly at resonance. – Andy aka May 24 '23 at 14:43
For a overdamped series RLC, at 0 Hz (DC).
That's when energy is stored just in the capacitor. There is no current, so no power is wasted in the R and L.
Davide Andrea
  • 16,164
  • 62
