I'm looking to use the MAX11301 for a project, in reviewing the datasheet i'm confused by exactly what the supply voltage required would be. I need to use some of the ports in the DAC analog output mode from 0-10V. I'm planning to supply the MAX11301 with 0 for AGND, DGND, and AVSSIO and +12V for AVDD, AVDDIO, and DVDD.
Will I be able to reliably have an analog output of 0-10V or is it required that AVSSIO be set to a value ~ -2V as the datasheet seems to suggest. Ideally I don't want to add the components to create the -2V supply.
Datasheet here: https://www.analog.com/en/products/max11301.html#product-overview
