I recently trying to develop on LCD screens, and I saw the TFT LCD interfacing with the high-density STM32F10xxx FSMC (AN2790 Application note)
and I was going along the way with the Application note just changed everything for my ili9488 and H7 board. In short, it didn't work, and I hoped for a bit of help with analyzing if there is any problem with the timing configuration or address.
Pin A20 for RS. Pin NE1 for CS. FMC clock is 160Mhz.
#define LCD_DATA    (volatile uint32_t *)(0x60000000 | 0x0200000)   // Base address of FMC data memory region
#define LCD_COMMAND (volatile uint32_t *)(0x60000000)               // Base address of FMC command memory region
and timing configuration:
  Timing.AddressSetupTime = 1;
  Timing.AddressHoldTime = 1;
  Timing.DataSetupTime = 32;
  Timing.BusTurnAroundDuration = 0;
  Timing.CLKDivision = 16;
  Timing.DataLatency = 17;
  Timing.AccessMode = FMC_ACCESS_MODE_B;
  /* ExtTiming */
  ExtTiming.AddressSetupTime = 1;
  ExtTiming.AddressHoldTime = 1;
  ExtTiming.DataSetupTime = 5;
  ExtTiming.BusTurnAroundDuration = 0;
  ExtTiming.CLKDivision = 16;
  ExtTiming.DataLatency = 17;
  ExtTiming.AccessMode = FMC_ACCESS_MODE_B;
am I wrong?
xmeety
  • Why do you access the memory as 32-bit word if the bus is 8-bit? Why do you add 0x200000 if 2^20 is 0x100000? – Justme May 17 '23 at 08:54
  • Your `LCD_DATA` is defined incorrectly. It should be 0x60100000, not 0x60200000. – brhans May 17 '23 at 12:15
0 Answers0
