If I understand correctly the process to assemble multi-layer PCBs, two-sided boards are made, with separators intertwined, and they are then pressed together. The two-sided boards have already been etched, which in theory leaves an uneven surface. When pressed together, it then appears to me that one of two things should happen:
a) The thickness of the separating layers is preserved but they suffer deformation, in which case the PCB would end up looking uneven at the end (probably not what happens?)
b) The parts of the separators above copper are pressed more than those above etched areas, thus yielding even surfaces, but with higher densities of separating material. This in turn probably changes the dielectric constant which might cause some (probably tiny) signal integrity issues (I believe?)
Is one of the above two variants correct?
