I am trying to write a code that converts binary to thermometer code. Thermometer (a.k.a. unary) coding is frequently used in digital systems applications to represent a natural number.
In a thermometer code, an N-bit binary number is represented by a (2 ** N)-bit digital word, which has m zeros followed by (N - m) ones or vice-versa. Basically, if you have a 4-bit binary number say 0110 (decimal is 6), the equivalent thermometer code will be of width 2^4 (=16), and its value will be 6 ones following 10 zeroes (0000000000111111).
module model (
    input [7:0] din,
    output reg [255:0] dout
logic [255:0] tempout;
int count;
always @ (*) begin
    count  <= din;
    tempout<= '0;
end
generate
    for (genvar i=0; i <= count; i++) begin
        tempout[i] = 1;
    end
endgenerate
assign dout = tempout;
endmodule
I am getting the following error for this code:
%Error:  Loop unrolling failed.
%Error-UNSUPPORTED:  Unsupported: Can't unroll generate for; Unable to unroll loop
For error description see https://verilator.org/warn/UNSUPPORTED?v=4.228
What is wrong with my code?
I have a working code also, but it goes through the loop 2^N number of times, and I want to reduce that.
localparam LP_DATA_SIZE = 8;
generate
    for (genvar i = 0; i < 2**LP_DATA_SIZE; i++) begin
        assign dout[i] = (i <= din);
    end
endgenerate
toolic
  • 5,637
TyzonKidd
    Your "working code" is the correct way to do this. The number of iterations of a `for` loop must be known at compile time; it can't be controlled by an input port. – Dave Tweed May 14 '23 at 10:51
    +1 Congrats for the well written question. *"it goes through the loop 2^N number of times"* It actually doesn't. It as hardware description language, and your interpretation seems to be more related to software. – devnull May 14 '23 at 12:03
You get the Verilator error message because the generate for loop needs a constant for the end condition, not a variable. You can't use count for the end condition because it is a variable (int). Your "working code" correctly uses a constant (localparam) for the end condition.
Another problem with the code is that the following assignment to tempout either needs the assign keyword, or it must be inside an always block inside the generate construct:
tempout[i] = 1;
Also, you would be making assignments to tempout from multiple places (the 1st always block and the generate) which would cause contention.
There is no concern for your working code. That is the proper way to describe the hardware you want. The for loop simply creates 256 parallel assignments (one for each bit of dout), which is what you are trying to achieve.
toolic
  • 5,637
