From this datasheet: https://www.murata.com/products/productdata/8807040057374/uhe12-30w.pdf?1617679818000
"Note: The Sense and VOUT lines are internally connected through 10Ω resistors. Nevertheless, if the sense function is not used for remote regulation the user should connect the +Sense to +VOUT and –Sense to –VOUT at the DC/DC converter pins."
Yet in the section about using the trim pin it says
"A resistor connected from the Trim (pin 9) to the –Output (pin 7), or –Sense where applicable, will increase the output voltage for all models with the exception of the 1.2V models, which will decrease the output voltage in this configuration"
That "or" throws me off a little. Figure 8 shows a dotted line from -sense to -output. I've looked at some other datasheets and application notes for similar DC-DC converters and they all seem to say that the + and - outputs should be tied to their + and - sense pins.
One of the reasons I ask is that i've seen some applications of this converter where the sense pins are left floating. The converter seems to work but i'm curious what the drawbacks are (if any).
Edit: I'm gonna add this here from page 4 as an extra nail in the coffin.
Also, based on the ordering guide, there may be no sense pins at all! This explains the applications i've seen where they are not connected to the outputs.
