More specifically what information can one extract from a root locus drawing without calculating the transfer function and then using Routh Hurwitz or other techniques? Essentially, what information does the Root Locus alone give us?
Ahsan Yousaf
  • 211
    [Take your pick](https://www.google.com/search?q=What+does+the+root+locus+tell+us+exactly&rlz=1C1ONGR_en-GBGB999GB999&oq=What+does+the+root+locus+tell+us+exactly&aqs=chrome..69i57j69i60.1232j0j15&sourceid=chrome&ie=UTF-8) – Andy aka May 04 '23 at 13:18
The Root Locus shows you how the zeros and the poles of your system change when you change a parameter. This is very useful to study and modify the behavior of your system by adjusting that parameter.
For example, converting a high order system to a lower order one by changing its gain. Root locus, can help us in the design by selecting the operation point (that yield the required characteristics) on the root locus. If there will be more than two poles in the system, the dominant poles will be of interest.
In this example, you can see how for different values of gain K you can choose the behavior of the system from unstable to stable, looking only to the position of the poles in te RL. "Reference"
https://www.researchgate.net/figure/Root-locus-plots-of-a-continuous-model-with-a-delay-of-T-015-s-as-approximated-by-a_fig9_277722689
Santiago L
  • 116
  • Thanks for your answer. – Ahsan Yousaf May 04 '23 at 13:59
  • As @andy-aka pointed out, Google has some answers to this. I found this page very illustrative, you might want to take a look at it. [link](https://lpsa.swarthmore.edu/Root_Locus/RootLocusWhy.html#:~:text=The%20root%20locus%20plot%20indicates,will%20give%20us%20good%20results) – Santiago L May 04 '23 at 14:04
