What I'm not understanding is how only 4 PDOs could possibly be useful when a node can presumably have dozens of unique data it wants to be able to send.
You're not limited to only 4 PDOs. The CANopen standard defines 4 default RPDOs and TPDOs.
The default PDO communication parameters are:
- RPDO1: object 0x1400
- default CAN-ID: 0x200 + NodeID
- RPDO2: object 0x1401
- default CAN-ID: 0x300 + NodeID
- RPDO3: object 0x1402
- default CAN-ID: 0x400 + NodeID
- RPDO4: object 0x1403
- default CAN-ID: 0x500 + NodeID
- TPDO1: object 0x1800
- default CAN-ID: 0x180 + NodeID
- TPDO2: object 0x1801
- default CAN-ID: 0x280 + NodeID
- TPDO3: object 0x1802
- default CAN-ID: 0x380 + NodeID
- TPDO4: object 0x1803
- default CAN-ID: 0x480 + NodeID
Apart from these default PDOs, you can implement up to 512 RPDOs and 512 TPDOs per device. The ranges 0x1404..0x15FF and 0x1804..0x19FF are reserved for manufacturer specific RPDOs and TPDOs, respectively.
From what I understand these devices could send this data using COB ID 0x181-0x184 and 0x281-0x284 for PDO1 and PDO2 respectively
The COB-IDs 0x181..0x184 are the default TPDO1 CAN-IDs for nodes 1 to 4. And COB-IDs 0x281..0x284 are the default TPDO2 CAN-IDs for nodes 1 to 4.
An important thing to note: you're not limited to use the default CAN-ID scheme (eg. 0x180 + NodeID for TPDO1, etc.). You may configure any CAN-ID in the range 0x180 .. 0x57F for any RPDO or TPDO.
Another thing to note: you can map any TPDO to any RPDO of multiple CANopen devices. If a device doesn't need all data mapped into the specific TPDO, it can configure RPDO dummy mappings to ignore certain parts of said TPDO.
EDIT 1
Going back to the environmental sensor. Let's say I've now defined two custom TPDOs for the data that I want these sensors to be able to share. How do I differentiate between PDOs I receive from different devices?
PDOs are differentiated by their CAN-ID. You can map a TPDO of one device to an RPDO of multiple other devices. You just have to make sure the RPDO COB-IDs match the TPDO COB-ID.
As an example, let's assume you've configured a TPDO with a COB-ID of 0x181. You can now configure multiple other CANopen devices to have an RPDO COB-ID of 0x181. This means said TPDO will be mapped to all other devices having an RPDO configured to have the same COB-ID as the TPDO.
Do I need to manually reserve N addresses between each PDO to allow for the node ID of each node to be added? In that case, the more nodes I have, the fewer PDOs I can represent? Is that correct? For example, with a full bus of 127 devices, only 8 PDOs (4 default + 4 custom) could be supported by all of them?
You have a total number of 512 RPDOs and 512 TPDOs per device. But overall the PDO COB-ID range spans 0x180..0x57F, which means there is a system-wide number of 1024 PDOs. These have to be shared among all 127 devices. Theoretically, if two devices use up 512 TPDOs each, there won't be any TPDOs left for subsequent devices.
If the 1024 TPDOs containing 8 bytes each isn't sufficient, you might want to consider upgrading your CAN bus to CAN FD.
EDIT 2
Just to be abundantly sure- if I have a device that I want to transmit 16 x 64-bit values using PDO, this would require 16 PDO addresses. Now if I wanted to deploy many of these devices on the same network, I would be limited to supporting (512/16=) 32 devices. Is that correct?
First of all, I had to correct a mistake above. Per device you can configure up to 512 TPDOs and 512 RPDOs. But system-wide you have 1024 TPDOs and 1024 RPDOs (range: 0x180..0x57F) available.
If each device uses 16 transmit PDOs (16 x 64-bit), you could support up to (1024/16=) 64 devices.
The question is, do you really need to transmit all 16x 64-bit values using PDO, or is it possible to partially use the SDO protocol?
It seems like a lot of careful planning is required to define the OD and PDO mapping for each device to ensure none overlap and that the host is mapping each to an RPDO. Can you recommend any resources to learn about how this is done?
If it's really this straightforward, so that each device uses 16 TPDOs, I'd keep it simple and assign COB-IDs 0x180..0x18F to node 1, 0x190..0x19F to node 2, ... 0x570..0x57F to node 64. The RPDOs have to be configured appropriately, to whichever devices needs the TPDOs.
For questions regarding the CANopen application layer and communication profile, I always consult CiA 301.
