I'm simulating the following circuit in PySpice:
In this configuration, the N-JFET is always in saturation mode, as you can see by the plot of Vds - (Vgs - Vto) = Vds - Vgt, which is always positive:
Voltage Plots
Hence, the value of Id should be given by the following equation, according to the S&H model:
$$ I_d = 0.5 \beta (V_{gs} - V_t)^2 (1 + \lambda V_{ds}) $$
However, when I compare the value of the measured Id = (Vdd - Vd) / Rd to the one calculated from the formula above, I get the following mismatch:
Could anybody help me on what I missed here? Below you can find the Python code:
import numpy as np
import matplotlib.pyplot as plt
from PySpice.Spice.Netlist import Circuit
from prefixed import Float
def main():
    F0 = 20  # [Hz]
    FS = 48000  # [Hz]
    temp_c = 20  # [celsius]
    A = 1.0  # [V] amplitude, linear
    T = 0.1  # [seconds]
    # Spice circuit, based on the LSK189A from LTSpice
    circuit = Circuit('JFET')
    LSK189A = circuit.model("LSK189A", "NJF",
                            Beta="2.2m",
                            Betatce="-0.5",
                            Vto="-1.13",
                            Vtotc="-2.5m",
                            Lambda="4.3m",
                            Is="3f",
                            Xti="0",
                            Isr="0",
                            Alpha="30u",
                            N="1",
                            Rd="11",
                            Rs="30",
                            Cgd="3.19p",
                            Cgs="2.92p",
                            Fc="0.5",
                            Vk="120",
                            M="320m",
                            Pb="0.8",
                            Kf="0.0009f",
                            Af="1",
                            Gdsnoi="2.15",
                            Nlev="1",  # changed from original 3
                            Mfg="Linear_Systems",
    # component values
    Vdd = 9.0
    Rg = 1E6
    Rd = 4.4E3
    Rs = 1E3
    # Netlist
    circuit.V('Vdd', 'vdd', circuit.gnd, Vdd)
    circuit.SinusoidalVoltageSource(
        'in', 'gate', circuit.gnd, amplitude=A, frequency=F0)
    circuit.R('Rg', 'gate', circuit.gnd, Rg)
    circuit.R('Rd', 'vdd', 'drain', Rd)
    circuit.R('Rs', 'source', circuit.gnd, Rs)
    circuit.J('JFET', 'drain', 'gate', 'source', model="LSK189A")
    jfet_spice_params = {
        p.upper(): LSK189A._parameters[p]
        for p in LSK189A._parameters
    plt.figure()
    plt.title('Id x t')
    # Spice model
    simulator = circuit.simulator(
        temperature=temp_c, nominal_temperature=temp_c)
    # analysis = simulator.dc(Vin=Vsl)
    analysis = simulator.transient(step_time=1/FS, end_time=T)
    y_id_spice = (np.array(analysis["vdd"]) - np.array(analysis["drain"])) / Rd
    y_vgt_spice = np.array(
        analysis["gate"]) - np.array(analysis["source"]) - Float(jfet_spice_params["VTO"])
    y_vds_spice = np.array(analysis["drain"]) - np.array(analysis["source"])
    # if > 0 then saturation
    y_limit_spice = y_vds_spice - y_vgt_spice
    t = np.array(analysis.time)
    plt.plot(t, y_id_spice, label="Id_spice")
    Id_spice_calc = (1 + Float(jfet_spice_params["LAMBDA"]) * y_vds_spice) * 0.5 * Float(
        jfet_spice_params["BETA"]) * y_vgt_spice**2
    plt.plot(t, Id_spice_calc, label="Id_spice_calc")
    plt.xlabel('T [s]')
    plt.ylabel('Id [A]')
    plt.margins(0, 0.1)
    plt.grid(which='both', axis='both')
    plt.legend()
    plt.figure()
    plt.title('V x t')
    plt.plot(t, y_vgt_spice, label=f"Vgt")
    plt.plot(t, y_limit_spice, label=f"Vds-Vgt")
    plt.xlabel('T [s]')
    plt.ylabel('V [V]')
    plt.margins(0, 0.1)
    plt.legend()
    plt.show()
if __name__ == "__main__":
    main()
ocrdu
  • 8,705
  • 30
  • 42
edwillys
  • 96
  • Did you try messing around with the threshold voltage? – Andy aka Apr 24 '23 at 17:10
  • No I haven't. Vto is a fixed SPICE parameter. I did try with different NJT models though. The mismatch was also there. – edwillys Apr 24 '23 at 17:24
  • What is `Vgt`? Did you mean `Vgs`? – Ste Kulov Apr 24 '23 at 20:01
    `Vgt = Vgs - Vt` – edwillys Apr 24 '23 at 20:08
  • OK, gotcha. Never seen it notated like that. – Ste Kulov Apr 24 '23 at 22:16
  • Where did you get the `0.5` factor from? – Ste Kulov Apr 24 '23 at 22:20
  • My reference was the Sedra/Smith Microelectronic Circuits book. There the multiplying factor in the saturation region is defined as `1/2 * kn * W/L`. I assumed that `kn * W/L` was the equivalent of the SPICE's beta – edwillys Apr 25 '23 at 09:24
  • That's for MOSFETs, hence the `W` and `L`. My edition of Sedra/Smith (the 5th one) doesn't even cover JFETs. The JFET equation is defined differently. – Ste Kulov Apr 25 '23 at 16:27
  • Yes, that is the same one I have. The Shichman and Hodges should apply in a similar way, as the only difference is the silicon dioxide layer at the gate. JFETs also have W and L, right? Another place where I saw it was [this paper](https://sbmicro.org.br/sforum-eventos/sforum2016/05.pdf) – edwillys Apr 26 '23 at 06:57
    @edwillys `W` and `L` are only used for MOSFETs...at least in SPICE. Anyway, I think the problem is if someone says they're using the Shichman-Hodges (or any) model for something (anything), you need to see how they explicitly implement it and define the parameters. For SPICE it's implemented a certain way, and the transconductance parameter is different between JFETs and MOSFETs. Besides the textbook mentioned in the answer below and the ngspice manual, you can also take a look at the original SPICE2 thesis for the implementation: https://www2.eecs.berkeley.edu/Pubs/TechRpts/1975/9602.html – Ste Kulov Apr 27 '23 at 02:05
The 0.5 factor should not be there in your calculation. See 3-22 page 143 of 2nd edition Semiconductor Device Modeling With Spice (Guiseppe et al.) which is the same equation as you have but the 0.5 has been rolled into \$\beta\$.
The remaining discrepancy in the static model is mostly accounted for by Rs (30Ω in the 'A' bin model), which reduces Vgs.
I presume the 'B' model is intended to be closer to typical with 'A' and 'C' representing outliers..
Spehro Pefhany
  • 376,485
  • 842
    Hmmm...I noticed the same thing as you, but there still remains a discrepancy. https://i.stack.imgur.com/5HhU4.png – Ste Kulov Apr 24 '23 at 22:42
  • @SteKulov That's strange, something else is going on. – Spehro Pefhany Apr 25 '23 at 00:37
    Oh, I think I understand now. I had to dissect the Python code to figure it out. He's using the Vds and the Vgs values calculated via the SPICE engine where Beta=2.2m, but then he's using those values along with the wrong Beta=1.1m to calculate Ids. Changing the Python code to remove the `*0.5` factor and make `Rs=0` is confirmed to have the plots line right on top of each other. https://i.stack.imgur.com/rWlNX.png – Ste Kulov Apr 25 '23 at 01:59
  • Thanks for having a deep look in the code @SteKulov. Spehro: Very nice catch with the internal Rs value affecting Vgs. Similarly, I assume, one should need to set Rd to 0 ohms in order to account for the discrepancy in Vds, which plays a role in the channel length modulation. Unfortunately I don't have access to this book. Could you please clarify what the A, B and C models are? Also, I assume that if the 0.5 factor is not present in the saturation formula for Id, a factor of 2 should be accounted for in the triode region, correct? – edwillys Apr 25 '23 at 09:34
    I don't *know* what the A B C are, I just see that they're available models at the manufacturer and don't line up with any known designations on the parts. There is a very wide range of possible Idss and if you look at the Idss for each of the models you get 2.6mA, 5.6mA, 10.8mA respectively. Datasheet limits for Idss are 2.5mA and 15mA with 5mA typical, so the B model is closest to typical. Rd doesn't make nearly as much difference as Rs because it doesn't affect Vgs. – Spehro Pefhany Apr 25 '23 at 13:27
    @edwillys If you don't have access to the book you can take a look at Equation 9.5 in Section 9.2.2 of the ngspice manual: https://ngspice.sourceforge.io/docs.html – Ste Kulov Apr 25 '23 at 16:32
  • Thanks @SteKulov! – edwillys Apr 26 '23 at 06:50
    @edwillys Also, you may be able to directly access [Semiconductor Device Modeling With Spice, 2nd ed.](https://archive.org/details/semiconductordev0000mass/mode/2up?view=theater&ui=embed&wrapper=false). – periblepsis Apr 30 '23 at 23:42
