What happens if a PT100 such as the P1K0.232.6W.B.010 is exposed to higher temperatures, e.g. at 700°C instead of its rated upper limit of 600°C?
Does something destructive happen that damages the PT100 fast or over time or is just accuracy affected?
Is the highest temperature limit given by the sensing element itself or by its case or connection?
Velvel
  • 3,591
  • 30
Hyp
  • 671
  • bad link ?? no result ... – citizen Apr 20 '23 at 14:33
  • corrected, thanks for pointing it out – Hyp Apr 20 '23 at 14:36
    Hmmm ... from the datasheet it looks like long term stability might be affected at the maximum temperature, so one would assume at temperatures exceeding the maximum recommended, this will be even more adversely affected. It looks like the time spent at a particular temperature may also be an important factor. Probably best to check with IST directly as they would know exactly what the effect will be. Otherwise chose another similar component with higher temp ratings to allow for the extra margin you may expect. – citizen Apr 20 '23 at 14:54
0 Answers0
