Is it possible to use SIMPLIS to draw the gain curve of the LLC converter?
Because FHA analysis is not very accurate when the operating frequency is above the resonant frequency.
If it can, what kind of element I should use in SIMPLIS.
You can draw a basic LLC circuit in any simulator, and feed it with sin wave while stepping frequency and/or load, and then you can observe the resonant tank gain at these frequencies similar to the graphs you attached. This way, what the simulator will show you, is not quite exact (no parasitics are considered), but it is good enough to design and predict the behavior of a physical LLC converter.
upload file enter link description here
