I am looking for the SMD below. Code "46" and vertical "L".
It is used in a latch circuit and could be a NAND gate or equivalent, something like a flip-flop circuit.
Here is the link to a circuit using this IC.
Any ideas?
Any ideas?
It appears to be a MBT3946 NPN-PNP transistor pair. datasheet.
The other transistors on that board appear to be: MUN2211 (8A) transistor with input resistors datasheet. (Found pretty easily through Ultimate SMD Database)
You can confirm by tracing out portions of Pololu board per your link, and comparing with their input circuit descriptions, in particular CTRL
to base of an NPN through 4K7 resistor.
