I have tried to flash/debug Nucleo F303RE using STMCubeIDE and I have encountered several problems.
First when trying to start debugging I receive following message:
"Starting server with the following options:
SWD Debug : Enabled
InitWhile : Enabled
Error in initializing ST-LINK device.
Reason: ST-LINK firmware upgrade required. Please upgrade the ST-LINK firmware using the upgrade tool."
Then when I select "Open in update mode" in "STLinkUpgrade 3.4.0" tool I receive following message:
"Unexpected error during opening (1)"
Additionally STLinkUpgrade shows:
Current Firmware:
Type:
Version: Unknown
Update to Firmware: Unknown
It looks strange. It is not driver issues mentioned in STM documentation (Before connecting the Nucleo-64 board to a Windows 7, Windows 8, or Windows 10 PC via USB, a driver for ST-LINK/V2-1 must be installed. It can be downloaded from the www.st.com website. In case the STM32 Nucleo-64 board is connected to the PC before installing the driver, the PC device manager may report some Nucleo interfaces as “Unknown”.) because:
- I have downloaded and installed en.stsw-link009
- I am using Nucleo G491RE board and this board is working fine (no ST-Link issues)
I have also tried to connect using STM32CubeProgrammer and I was able to do it after unplugging and plugging again the board. It looks like this tool does not have problems with connection:
15:15:21 : UR connection mode is defined with the HWrst reset mode
15:15:21 : ST-LINK SN : 066DFF343056363043032707
15:15:21 : ST-LINK FW : V2J33M25
15:15:21 : Board : NUCLEO-F303RE
15:15:21 : Voltage : 3.25V
15:15:21 : SWD freq : 4000 KHz
15:15:21 : Connect mode: Normal
15:15:21 : Reset mode : Software reset
15:15:21 : Device ID : 0x446
15:15:21 : Revision ID : Rev Y
15:15:21 : Debug in Low Power mode is not supported for this device.
15:15:21 : UPLOADING OPTION BYTES DATA ...
15:15:21 : Bank : 0x00
15:15:21 : Address : 0x1ffff800
15:15:21 : Size : 16 Bytes
15:15:21 : UPLOADING ...
15:15:21 : Size : 1024 Bytes
15:15:21 : Address : 0x8000000
15:15:21 : Read progress:
15:15:21 : Data read successfully
Interestingly STM32CubeProgrammer Updater shows:
"No Updates available"
"Current version: v2.13.00"
How can I make it working under STMCubeIDE?
